Taking out Ignition?
owenexile
PostPosted: Thu Oct 28, 2010 10:42 am    Post subject: Taking out Ignition? Reply with quote
Is it hard to pull the ignition? I need to connect a immobiliser wire up again , and i cant reach it from underneath the dash because the wire is about 3cm long. Any precautions i need to take here?
Thanks
924 1982 N/A
For some reason theres always a earth problem somewhere with this car...
leadfoot
PostPosted: Thu Oct 28, 2010 8:07 pm    Post subject: Reply with quote
Center the steering wheel before you take it off.
don't crossthread the housing bolts when you screw back in the switchgear.
Only if you need to take out the barrell are there tricky bits, all pretty straight forward stuff.
you'll need a 24mm socket and a short extention bar for your ratchet
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Fri Oct 29, 2010 4:00 am    Post subject: Reply with quote
Why go to all that trouble?
Grab the wires running to the ignition switch up behind the fuse/relay pane, and cut in there.
owenexile
PostPosted: Fri Oct 29, 2010 5:26 am    Post subject: Reply with quote
The wire im looking for is a wire witch is all by itself and comes straight out of the ignition and doenst go anywhere and one wire of the immobiliser needs to connect up to it.
924 1982 N/A
camfella
PostPosted: Fri Oct 29, 2010 6:48 am    Post subject: Reply with quote
Clarkes garage has some helpful articles:
http://www.clarks-garage.com/shop-manual/elect-25.htm
cheers.
1987 924s
owenexile
PostPosted: Sat Oct 30, 2010 3:55 am    Post subject: Reply with quote
Thanks Mate , that really helped.
924 1982 N/A
camfella
PostPosted: Sat Oct 30, 2010 8:54 am    Post subject: Reply with quote
I only knew about it cause someone else on the board helped me out!
Love this message board for getting help, its great.
1987 924s
RC
PostPosted: Mon Nov 01, 2010 2:54 am    Post subject: Reply with quote
Besides that, even a remotely intelligent car thief will look under/ rip off wires at the ignition switch. Doesn`t take much brains to jump a relay or cut & twist 2 wires.
Another relay at the fuse/ relay panel is more inconspicuous. Rewire or protect the fuel pump circuit as well or even instead. So simple to jump the battery to coil +, why bother with the key.
BTW, no I`m not a car thief.
Allan @ DTA wrote:
