What the heck is this?
Gus
PostPosted: Thu Oct 28, 2010 10:03 am    Post subject: What the heck is this? Reply with quote
Ok, I'm somewhat of a noob, but even my not-so-mechanically-noob friends seem to have no idea what this might be:
I found it on the end of my number 1 spark plug, covering the electrode end. It slots into the spark plug hole, and the spark plug in the back of this. I removed it and the car feels a lot better.
What is it? What would be the purpose to difficult the access of the spark to the mixture in the cylinder?
Min
PostPosted: Thu Oct 28, 2010 11:04 am    Post subject: Reply with quote
Looks like a 'spark plug defouler' to me.
Min
Gus
PostPosted: Thu Oct 28, 2010 8:12 pm    Post subject: Reply with quote
...so, not something one would expect to find as if it's in daily use, right?
PostPosted: Fri Oct 29, 2010 2:19 am    Post subject: Reply with quote
Its pretty oily. . .I guess you'll find out whether it was helping after you've driven a while. You probably have bad valve seals.
stevekat
PostPosted: Fri Oct 29, 2010 7:56 pm    Post subject: Reply with quote
The 'defouler' separates the spark plug electrode from the immediate vicinity of the cylinder where oil due to wear or damage can wet and subsequently foul the spark plug, preventing ignition. Not a good sign.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
Gus
PostPosted: Sat Oct 30, 2010 9:17 am    Post subject: Reply with quote
I suspected bad seals already, from the ocasional puffs of smoke on startup.
I've ordered some, though it's unlikely that I'll have time to swap them soon.
Btw, on a 1 to 10 rating, how hard is it to swap the seals on these engines? Would you say an amateur with a haynes and a torque wrench could take it on?
PostPosted: Sat Oct 30, 2010 9:39 am    Post subject: Reply with quote
Do a compression check, I'm guessing the rings are shot or broken.
To do the valve seals you have to:
turn motor to TDC and mark rotor and distributor
remove distributor
remove the timing belt.
remove valve cover.
Remove camshaft.
Remove lifters (KEEP THEM IN ORDER)
Apply air pressure to each cylinder one at a time
Remove valve springs using an expensive valve spring tool.
Remove seals (use a set of valve seal pliers) A PITA to pull off the guides.
Install new seals (Use the correct driver)
Repeat for the other 3 cylinders
Assemble in reverse order
Or just yank the head and do a valve job while you're in there.
stevekat
PostPosted: Sat Oct 30, 2010 10:30 am    Post subject: Reply with quote
You forgot the part about using pushing rope down into the cylinder via the spark plug hole, or compressed air so the valves don't drop into the cylinder.
If it is a 931, it can certainly be ring/piston damage from detonation.
PostPosted: Sat Oct 30, 2010 10:37 am    Post subject: Reply with quote
Yep, trying to watch the Penguins at the same time. Also forgot to mention that the valve springs need to be removed using an expensive valve spring tool. I'll edit the post.
PostPosted: Sat Oct 30, 2010 10:55 am    Post subject: Reply with quote
http://www.toolsource.com/valve-spring-compressor-audi-porsche-p-106249.html
