Drizz
Joined: 10 Nov 2010 Posts: 93 Location: Dekalb, Illinois
Posted: Sat Nov 13, 2010 10:08 am Post subject: Alternator/Battery |
Hey Forum, just had a quick question. I just replaced the batter in my car, but I know the alternator isn't working. I'm in the course of replacing the alternator but it hasn't shipped yet. I was in the course of messing around with other things in the car and noticed that the headlights aren't popping up anymore. I know that the alternator recharges the battery, and in my case, isn't happening right now. Are the headlights not popping because I have ran the battery down to a less than required voltage to pop open the headlights?
Thanks for reading my ramble,
~Drizz _________________ 1979 924 Sebring Edition, "Claire" |
Posted: Sat Nov 13, 2010 10:34 am Post subject: |
What kind of car did you get? 924, 928, 944, 924S, 968? _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
joejax
Joined: 02 Dec 2009 Posts: 919 Location: Jacksonville,FLA,USA
Posted: Sat Nov 13, 2010 10:36 am Post subject: |
What kind of batter did you use?  _________________ I got nothin'
Uhhh...you got any pics? |
Drizz
Posted: Sat Nov 13, 2010 10:47 am Post subject: |
I have a '79 924, I'll have to get back to you on the battery voltage/amps.
EDIT: The battery is a Duralast 48-DL, Cranking Amps 875, Cold Cranking Amps 700, Reserve Capacity 115
I just don't understand if the headlights are directly related to the current voltage of the battery, if they are, it would make sense due to the alternator being faulty. _________________ 1979 924 Sebring Edition, "Claire" |
joejax
Posted: Sat Nov 13, 2010 11:01 am Post subject: Re: Alternator/Battery |
| Drizz wrote: | | I just replaced the batter in my car.. |
I was just joking about your type-o. Not too sure what the problem could be, fuse, relay, motor, bad wiring?
I would think 12 volts from the battery would make the lights go up. Good luck. _________________ I got nothin'
Drizz
Posted: Sat Nov 13, 2010 11:16 am Post subject: |
It WAS working, I flipped the lights off, then went to hit them back on...and they didn't pop back up. Think I might have blown a fuse?
Edit: The fog lights were working while the headlights were not, not neither work. It almost seems like it is battery related, unless headlights/flood lights run off the same fuse. _________________ 1979 924 Sebring Edition, "Claire" |
Barretts924
Joined: 02 Oct 2010 Posts: 18 Location: Independence, Oregon
Posted: Wed Nov 17, 2010 2:48 pm Post subject: |
| I also have a 79' 924 and it has the same problem, just the lights dont go down. The lights still work and all, and I also thought it was an alternator/battery problem. Most of the problems with my car have been alternator/battery related, so it wouldn't surprise me if that was it. |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Thu Nov 18, 2010 2:38 pm Post subject: |
The circuit to control the light movement is a tad complex and relies on a wheel on the end of the motor with three contacts. These can go a bit agly, but before you go to the trouble of dismantling it (not difficult, just takes a bit of time), check the socket plugging into the motor has all it's pins making contact. All it takes is for one to be loose and it doesn't work right.
Wade. |
