Stalling at Idle (IAC on a Lux?)
S.Devon
PostPosted: Wed Dec 01, 2010 6:19 am    Post subject: Stalling at Idle (IAC on a Lux?) Reply with quote
Hi folks,
I had fuel consumption problems a while ago and by leaning the mixture somewhat (using the adjusing screw by the throttle bodies) I got better fuel economy.. Thing is, it started to stall at idle, and it got worse to the point it now stalls whenever I slow down. Fully rich on that adjuster is the only time it wont stall at idle (so it's back to 10-15MPG).
Does the 1984cc Lux have an Idle Air Control (IAC) valve? I can't find anything on here or in the Haynes manual about it, but it seems my problem is a classic symptom of a clogged IAC valve Any other suggestions as to what might be causing this?
Thank you, Jason
PostPosted: Wed Dec 01, 2010 6:31 am    Post subject: Reply with quote
Vacuum leak(s). CIS hates vacuum leaks.
S.Devon
PostPosted: Sat Dec 04, 2010 6:11 am    Post subject: Reply with quote
Thanks Rasta Monsta.
