where can I get a new front sway bar link (78)
MGQ
PostPosted: Sun Jan 04, 2004 3:43 am    Post subject: where can I get a new front sway bar link (78) Reply with quote
I just got this car about 2 weeks ago, and it was such a nice day today I decided to start taking it apart.
on the list for today is a new thermostat which I have, and I looked at my passenger (right) side sway bar link, and it's broken.
I searched around on the internet and I can't seem to find one, is there a good source that I'm missing?
here it is before jacking the car up:
here it is after:
The other side is fine, I just don't know where to get the part from.
PostPosted: Sun Jan 04, 2004 4:00 am    Post subject: Reply with quote
You could weld it...
MGQ
PostPosted: Sun Jan 04, 2004 4:03 am    Post subject: Reply with quote
I'm going to weld it. does the "..." mean they are no longer available?
PostPosted: Sun Jan 04, 2004 4:07 am    Post subject: Reply with quote
I assume they are available from the dealer, but its a 15 minute job to remove that link, pull off the rubber parts and weld.
MGQ
PostPosted: Sun Jan 04, 2004 4:25 am    Post subject: Reply with quote
cool. That's what I'm in the middle of now, but I was thinking that would probably only be temporary, I'll figure it out. thanks!
PostPosted: Sun Jan 04, 2004 4:32 am    Post subject: Reply with quote
They are welded to begin with, maybe your welding will last as long.
PostPosted: Sun Jan 04, 2004 8:45 am    Post subject: Reply with quote
So how did it go?
welder
PostPosted: Mon Jan 05, 2004 6:52 am    Post subject: Reply with quote
Yes the end links can easily be welded. Unbolt the bottom piece from the control arm, and slide the other half off the stabilizer. Obviously, remove the rubber bushing and weld the two pieces together. No problem, a 5 minute welding job.
I have a 78 n\a currently under restoration.
PostPosted: Mon Jan 05, 2004 11:36 pm    Post subject: Reply with quote
Yeah, welding would be fine, unless the metal is too far corroded (have seen some like this). They can also be gotten from the dealer, or aftermarket places like Paragon.
MGQ
PostPosted: Fri Jan 09, 2004 11:04 am    Post subject: Reply with quote
I welded it up and put everything back together, and it works great! feels a little better and no more clunking sound!
I am amazed how clean this car is, the threads on the bottom of the link just turned and came off, no rust, no goo, no drama. I love this car!
Thanks for the help!
kevinlvy
PostPosted: Wed Dec 08, 2010 5:48 pm    Post subject: Reply with quote
i see, my friend's 924 has the same problem with his part i guess we would rule out of getting a sway bar link replacement and just weld the thing. thanks!
