Vacuum advance on distributor?
Bockscar
PostPosted: Sat Dec 18, 2010 3:26 pm    Post subject: Vacuum advance on distributor? Reply with quote
Hey guys,
When I bought my car, it came with a brand spanking new, but incomplete engine. What I mean by incomplete is that the engine itself was bolted in, but none of the electricals and very few of the vacuum hoses were hooked up..
I know that the NA engine has a vacuum advance on the distributor but, does the turbo engine have one? If it does, I need to find one because my engine is missing it
PostPosted: Sat Dec 18, 2010 5:16 pm    Post subject: Reply with quote
Putting the year of your car in your signature (under Profile) will get you more accurate responses.
My 1980 has a vacuum unit with advance (from throttle plate) and retard (from manifold vacuum. . .actually tapped from brake booster line).
If your vacuum sticker is missing I can shoot you a photo of mine.
Bockscar
PostPosted: Sun Dec 19, 2010 2:44 am    Post subject: Reply with quote
Whoops! I spaced that.. Fixed it now though!
According to the Haynes manual (albeit, the last 8 pages of it), my particular engine appears to have a 'Direct Ignition Timing Control' system which means it uses a hall sensor on the flywheel instead of a vacuum advance.
Brian
'79 924 - Restoration In Progress
'81 924 Turbo w/EFI - Scrapped
jbwheele
PostPosted: Mon Apr 18, 2011 6:39 pm    Post subject: thanks Reply with quote
Hey I think this just answered my new post Ill tap ma line from manifold vac to the retard side of dizy unit !
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
PostPosted: Tue Apr 19, 2011 1:30 am    Post subject: Reply with quote
'81-up 931s with DITC have a vac line to the DITC box that provides vac/boost level info for processing. DITC takes that, and the crank sensor signal, and intake air temp, then figures out how much spark advance or retard...
Not seeing the Vac line to DITC here, but as I recall it originates somewhere near "H" (the CSV) -
<click>
