tuf-924
Posted: Wed Jan 12, 2011 9:20 am Post subject: Head gasket |
Hey i just done a head gasket to my car i put everything back together but there are 3 wires that arnt connected they are brown located near the distributer i dont know where they connect to also my engine doesnt start there is spark and fuel pumping it cranks but doesnt kick over.
Does anyone know what to do? _________________ Vass... |
staticsan
Posted: Wed Jan 12, 2011 10:42 am Post subject: |
They're ground wires. Hook 'em onto any handy bolt on the intake manifold. I recall I have a few on the bracket holding the fuel line to the CSV.
Wade. |
tuf-924
Posted: Wed Jan 12, 2011 12:24 pm Post subject: |
Alright thanks man ill try it out cheers _________________ Vass... |
tuf-924
Posted: Wed Jan 12, 2011 6:16 pm Post subject: |
Do you know whag that wire is for? _________________ Vass... |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Wed Jan 12, 2011 10:15 pm Post subject: |
Brown is pretty much invariably a ground. _________________ Vaughan Scott
staticsan
Posted: Thu Jan 13, 2011 11:17 am Post subject: |
Also check there is a big copper ground strap. I remembered that later. Mine has (for some reason) two, both going from different points on the intake manifold to the body.
Wade. |
tuf-924
Posted: Thu Jan 13, 2011 5:53 pm Post subject: |
Ok thanks, one more thing i cant seem to be able to connect my thermostat up right what colour wires go into it? At the moment im asuming blue but i got 2 blue wires that can connect and a ground, iv got the ground and one wire connected but dont know where the other wire connects to? _________________ Vass... |
Posted: Thu Jan 13, 2011 10:58 pm Post subject: |
Uhhh... the thermostat is a purely mechanical device, on all cars. Perhaps you mean the thermo-time switch?? _________________ Vaughan Scott
tuf-924
Posted: Fri Jan 14, 2011 5:08 am Post subject: |
Its at the very back of the engine connects to the head _________________ Vass... |
Harm
Posted: Fri Jan 14, 2011 10:22 am Post subject: Re: Head gasket |
These sit in the flange on the back of the head.
TTS wires (brown connector):
—Red/White
—Green/White
Temp sender VDO 120°C, flathead connection:
—Blue/Yellow
Next to the flange sits the Oil Pressure Switch:
-G—Blue/White
-Wk—Blue/Black
HTH _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
tuf-924
Posted: Fri Jan 14, 2011 11:08 am Post subject: |
Sweet cheers man that helps alot _________________ Vass... |
tuf-924
Posted: Mon Jan 17, 2011 4:21 pm Post subject: |
Sorry man but where does the temp sender plug into? _________________ Vass... |
leadfoot
Posted: Mon Jan 17, 2011 4:48 pm Post subject: |
temp sender screws into the intake side of the coolant flange at the back of the head (small brass sensor 10mm with flat round connection that a female spade slots on to)
thermo time switch (TTS) is the sensor that screws into the bottom of the coolant flange
carbon fiber GT mish mash
Harm
tuf-924
Posted: Tue Jan 18, 2011 7:51 pm Post subject: |
Ye i got it swwet thanx guys yous helped heepz, now all i have to do is hope it starts when the battary is charged  _________________ Vass... |
