jacobscott209
Posted: Mon Jan 17, 2011 6:35 am Post subject: e-brake placement |
I'm getting a little sick of climbing out over my emergency brake lever. I'm not a small guy, I keep getting stuck between the steering wheel and lever when I try to get out. Anyone out there ever modified or moved the thing? _________________ 77924 |
Harm
Posted: Mon Jan 17, 2011 9:53 am Post subject: Re: e-brake placement |
Don't know of moving or modding the hand brake lever.
When you're getting in and out the car and the engine is turned off, leave it in gear so it doesn't roll…
When used when the engine is still running and you need to get in and out the 924 it still shouldn't be very difficult since it hides behind the drivers seat for the greater part. Using the handbrake is only a four or five ‘klicks’ up; Is yours not sitting up to high?
Now how to get it down.
FIRST You might want to adjust the rear drums a little tighter, make sure they are functioning allright. You have to adjust these regularly by hand depending on your way of driving, miles etc.
SECOND check if the emergency brake is still to loose…
Lift it two klicks* and you should already feel resistance when trying to turn the rear wheel (wheels of the ground/car on jackstands). Needs tightening? Behind the emergency brake lever, underneath the carpet, you will find a locknut and two cables that will allow you to adjust the force applied to the brakes.
See Haynes Chapter 9, §19 Emergency Break — adjustment.
HTH
Regards, Harm.
*You might want to grease the Pawl (klicky thing) when you're in there,
because it is known to fail at the most inconvenient moment imaginable …cliffs and such a like _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Mon Jan 17, 2011 4:10 pm Post subject: |
If it is in your way, it is way out of adjustment. . .it should barely come up. _________________ Toofah King Bad
jacobscott209
Posted: Mon Jan 17, 2011 4:33 pm Post subject: |
Seems to have a normal throw in comparison to other cars so i didn't think anything of it. It sits flush with seat level, it pulls up much further when engaged. pulls to about a 50 to 60 degree angle... What should it be doing? _________________ 77924 |
Posted: Tue Jan 18, 2011 1:13 am Post subject: |
Approximatly this-
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
jacobscott209
Posted: Tue Jan 18, 2011 3:44 am Post subject: |
I'm glad I asked. Looks like mines way out of adjustment. Thanks for the info. _________________ 77924 |
