Head gasket
tuf-924
PostPosted: Wed Jan 12, 2011 9:20 am    Post subject: Head gasket Reply with quote
Hey i just done a head gasket to my car i put everything back together but there are 3 wires that arnt connected they are brown located near the distributer i dont know where they connect to also my engine doesnt start there is spark and fuel pumping it cranks but doesnt kick over.
Does anyone know what to do?
Vass...
staticsan
PostPosted: Wed Jan 12, 2011 10:42 am    Post subject: Reply with quote
They're ground wires. Hook 'em onto any handy bolt on the intake manifold. I recall I have a few on the bracket holding the fuel line to the CSV.
Wade.
tuf-924
PostPosted: Wed Jan 12, 2011 12:24 pm    Post subject: Reply with quote
Alright thanks man ill try it out cheers
Vass...
tuf-924
PostPosted: Wed Jan 12, 2011 6:16 pm    Post subject: Reply with quote
Do you know whag that wire is for?
Vass...
PostPosted: Wed Jan 12, 2011 10:15 pm    Post subject: Reply with quote
Brown is pretty much invariably a ground.
staticsan
PostPosted: Thu Jan 13, 2011 11:17 am    Post subject: Reply with quote
Also check there is a big copper ground strap. I remembered that later. Mine has (for some reason) two, both going from different points on the intake manifold to the body.
Wade.
tuf-924
PostPosted: Thu Jan 13, 2011 5:53 pm    Post subject: Reply with quote
Ok thanks, one more thing i cant seem to be able to connect my thermostat up right what colour wires go into it? At the moment im asuming blue but i got 2 blue wires that can connect and a ground, iv got the ground and one wire connected but dont know where the other wire connects to?
Vass...
PostPosted: Thu Jan 13, 2011 10:58 pm    Post subject: Reply with quote
Uhhh... the thermostat is a purely mechanical device, on all cars. Perhaps you mean the thermo-time switch??
tuf-924
PostPosted: Fri Jan 14, 2011 5:08 am    Post subject: Reply with quote
Its at the very back of the engine connects to the head
Vass...
Harm
PostPosted: Fri Jan 14, 2011 10:22 am    Post subject: Re: Head gasket Reply with quote
These sit in the flange on the back of the head.
TTS wires (brown connector):
—Red/White
—Green/White
Temp sender VDO 120°C, flathead connection:
—Blue/Yellow
Next to the flange sits the Oil Pressure Switch:
-G—Blue/White
-Wk—Blue/Black
HTH
tuf-924
PostPosted: Fri Jan 14, 2011 11:08 am    Post subject: Reply with quote
Sweet cheers man that helps alot
Vass...
tuf-924
PostPosted: Mon Jan 17, 2011 4:21 pm    Post subject: Reply with quote
Sorry man but where does the temp sender plug into?
Vass...
leadfoot
PostPosted: Mon Jan 17, 2011 4:48 pm    Post subject: Reply with quote
temp sender screws into the intake side of the coolant flange at the back of the head (small brass sensor 10mm with flat round connection that a female spade slots on to)
thermo time switch (TTS) is the sensor that screws into the bottom of the coolant flange
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Harm
PostPosted: Tue Jan 18, 2011 1:21 am    Post subject: Re: Head gasket Reply with quote
See flange here: http://www.924board.org/viewtopic.php?p=310751#310751
See nail-head at ± ten o'clock?
tuf-924
PostPosted: Tue Jan 18, 2011 7:51 pm    Post subject: Reply with quote
Ye i got it swwet thanx guys yous helped heepz, now all i have to do is hope it starts when the battary is charged
Vass...
