myth busters
924turborox
PostPosted: Sun Jan 23, 2011 10:55 am    Post subject: myth busters Reply with quote
I've heard about the hype synthetic engine oils are getting.
Any truth about them?
Also, what about Royal Purple?
1980 porsche 924 turbo 5speed getrag gearbox
joecitizennn
PostPosted: Sun Jan 23, 2011 11:04 pm    Post subject: Reply with quote
if you have not heard anything about the deletion of ZDDP from standard engine oil in the last several years then you have some reading to do. Synthetic oil is a must for older cars unless you are running a diesel or race oil with adequate quantities of ZDDP.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
924turborox
PostPosted: Mon Jan 24, 2011 2:35 am    Post subject: Reply with quote
I had read and heard about the reduction/deletion (I'm not exactly sure which) of ZDDP which is why I was a bit worried about it.
Any particular synthetic that you'd recommend? as opposed to the Valvoline VR1 20w50 I'm using at the moment anyway.
CorsePerVita
PostPosted: Mon Jan 24, 2011 4:32 am    Post subject: Reply with quote
I prefer to stick with brad penn.
but oil is going to vary a lot with opinions.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
Rattlinbone
PostPosted: Mon Jan 24, 2011 4:57 am    Post subject: Reply with quote
I had the same question a while back. After a little time at the library reading consumer reports, scouring message boards and gathering opinions, the answer I came up with is that Valvoline VR-1 20w-50 or Kendall GT-1 20w-50 is the way to go. But apparently it's a matter of opinion.
Fred- 1979 924
joecitizennn
PostPosted: Mon Jan 24, 2011 6:45 am    Post subject: Reply with quote
Valvoline vr1 is fine, but not a good oil to keep in your engine for a long period of time. Synthetic is a better daily driving oil. The argument over what kind could go on for 1000 pages. I say you can't go wrong with Mobil 1.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
Julian
PostPosted: Tue Jan 25, 2011 2:20 am    Post subject: Oil Reply with quote
I switch everything I own to synthetic after break-in. Lawn mover, to work truck. My work truck has 180,000 miles on it. Last year I replaced the tranny so while I was that close I replaced the oil pump and rear seal.
The number 5 main bearings show no signs of wear still grey as they were when new. The truck still has the oil pressure that it did when new also.
Cost a little more, but I still change the oil between 2,500 and 3,000 miles.
When knurling guides the resizer at times will stop in the valve guide. When that happens I use synthetic oil to get the resizer to clear the valve guide. That's how slick that stuff is.
Draw back. If you have a gasket that might leak with regular oil, it will for sure with synthetic. It smells worse also, when it burns on an exhaust system.
PostPosted: Tue Jan 25, 2011 2:36 am    Post subject: Reply with quote
Hype? you write about synthetic oil like it was something new and unknown. Its been standard in the industri for years. Why not take advantage of 100 years of development I wont put anyhing other than a resonable specd synthetic in my cars, race car or daily driver dont matter (just different viscosity grades)..
PostPosted: Tue Jan 25, 2011 3:40 am    Post subject: Reply with quote
brad penn
It is not just synth/non-synth, it has to do with the flat-tappet overhead cam motors and zddp-deficient oils causing premature wear to followers and cams.....
but you pick what works for you
924turborox
PostPosted: Fri Jan 28, 2011 10:14 am    Post subject: Reply with quote
Thanks 924ers
I meant hype as in the kind I've been getting from people trying to sell me stuff.
