tuf-924
Posted: Wed Jan 26, 2011 11:46 am Post subject: Engine not starting |
Hey guys tried starting my car today seems like fuel isn't pumping through injecters 1 and 2, 3 and 4 pump alright but don't know what's the deal with the other 2 can anyone help? _________________ Vass... |
Jakkq
Joined: 29 Sep 2008 Posts: 810 Location: Omaha, Nebraska
leadfoot
Posted: Thu Jan 27, 2011 2:08 pm Post subject: |
so either the injectors are blocked or the port filters inside the fuel dizzy are.
pull your injectors and swap the 2 good ones to the lines on the bad ones and see if they pump fuel, this will tell you if it's definitely the injecotrs or the dissy.
There was a dissy rebuild post here somewhere on the board.
Could see if Tim in Canberra still has the fuel system, he was giving parts away...
carbon fiber GT mish mash
tuf-924
Posted: Thu Jan 27, 2011 9:06 pm Post subject: |
Nar it's all good now it was airblocked someone at work told me to bleed it now its pumping fuel through all lines, by now I have an electrical problem, when I crank it, It sparks for a few strokes then cuts out and won't spark at all :s Its confusing because its got power and fuel but the spark plugs only spark for a few strokes and then stop. Would you know anything about that?? _________________ Vass... |
