931/2 engine install...Whats the easiest way
jbwheele
PostPosted: Thu Feb 17, 2011 2:56 pm    Post subject: 931/2 engine install...Whats the easiest way Reply with quote
Hey is it easier to attatch all the forward exaust, wastgate, starter motor etc then squeeze it all in from the top or slide everything underneath and pull it upward? I remember doin my NA and I just stuck Tranny torque tube and engine all together then slid it under the car (with suspenseion removed) on a skateboard (for tranny) and creeper for engine. then lifted it into place, however I didnt have the awkward turbo s..t to deal with and this car has the suspension in and I am lazy nearly 20 years older as well....
Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap
PostPosted: Thu Feb 17, 2011 3:25 pm    Post subject: Reply with quote
Easiest way. . .make your wife do it.
We dropped it in with turbo and manifolds attached, then attached remaining exhaust plumbing and wastegate.
jbwheele
PostPosted: Thu Feb 17, 2011 7:55 pm    Post subject: Reply with quote
THats sweet, good relationships are built on hard work......hers........................................my wife likes the colour of ours.
Cheers Joe
Joe
Fifty50Plus
PostPosted: Fri Feb 18, 2011 1:05 am    Post subject: Reply with quote
Almost makes me feel guilty....
1982 924 NA race car - Sold
1981 924 Turbo sold
1982 924 Turbo sold
jbwheele
PostPosted: Wed Feb 23, 2011 11:19 am    Post subject: Its IN FINALLY Reply with quote
My install went slowly One hint If yo dont have an engine hoist trolley.....get one. I hoisted the engine up via a joist in the roof and a block n tackle and manouvered the car under it, what a hassle... also if your 931/2 clutch plate isnt perfect you just line it up so the engine can "float in and out of the guide tube freely then touching the plate with the shaft pressurise the clutch , wriggly slowly against the clutch plate should move it to allow the splines to fit and slide in .... dont wack it in cause you might bend a few spline faces which mkes it harder to lush it in, then use the bolts to clamp together.
Joe
