Andrew NZ
Posted: Tue Mar 01, 2011 6:57 pm Post subject: US or Euro G31? |
Hi, My mate has a spare G31 and wants to know if it's out of a Euro or a US car.
The serial number is 31/01/05811/(can't read the next bit)
Other numbers on the casings are 477 301 102 AA MB, and 931.301.301.OR
Does that tell us enough to work it out? _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
gegge
Posted: Tue Mar 01, 2011 7:37 pm Post subject: |
3101 is a G31 without LSD. MB stands for Euro 79-84
According to the technical document:
http://www.equipedic.se/docs/924/Porsche%20924%20technical%20Specif.doc _________________ Carl Fredrik Torkildsen
Andrew NZ
Posted: Tue Mar 01, 2011 7:57 pm Post subject: |
Thanks, I'll pass it on to him. _________________ Andrew
1977 RX924 race car
v8carreragts
Posted: Wed Mar 02, 2011 4:48 am Post subject: |
3101 means ROW version. The S/N needs a 12 at the end to have LSD. That spec sheet is somewhat misleading. 3102 is the US version. The other numbers are casting numbers.
You need the whole s/n to determine if it has LSD or just turn the output flange. if the other side turns the same way even if you try to hold it it has LSD. If both flanges can be turned opposite directions at the same time it does not have LSD. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze |
