Posted: Fri Feb 11, 2011 9:46 am Post subject: |
No title either.
BRILLIANT! _________________ Stefan
jbwheele
Joined: 09 Jun 2010 Posts: 72 Location: Invercargill New Zealand
Posted: Mon Feb 14, 2011 6:32 pm Post subject: Belt position on pulley ? |
Hey is it just me or do all these Cam belts sit slightly off the front of the cam toothed pulley gear. My NA back in Oz had the belt is forward about 1 eight of an inch , the latest 931 motor im doin is the same, surely its supposed to sit flush or is the something Im doin wrong again?  _________________ Joe
82 932 Stripped bare full rebuild
80 932 GT Lookalike Engine S2 swap |
Posted: Tue Feb 15, 2011 12:31 am Post subject: |
Mine does the same thing. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Wed Feb 16, 2011 2:20 am Post subject: |
Smoothies' belt on either side is not overhanging..
  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Feb 16, 2011 7:25 am Post subject: |
Do you have a spacer/washer behind that cam gear? _________________ '83 944 Track car.
Posted: Wed Feb 16, 2011 11:31 am Post subject: |
No sir.
-And no other forms of trickery-deceit-shanana-nanagans are being employed..
I'd first suspect your tensioner wheel and/or crank pulley since they guide the belt. (You wouldn't have put a washer behind your tensioner, right?)
-Or could your cam shaft be recessed too far? (Don't know if that's even possible..I'd suspect not.)
With some luck I'll remember to take valve-cover-to-cam-sprocket distance, and belt width measurements tomorrow. _________________ "..it's made in Germany. You know the Germans always make good stuff."
jbwheele
Posted: Wed Feb 16, 2011 6:55 pm Post subject: Yeah Weird |
The Crank pulley is already touching the front of the belt or near enough, so if it relys on that then perhaps its the end float of the crank ? anyone else have a look for us and we should do a survey _________________ Joe
Posted: Thu Feb 17, 2011 4:11 am Post subject: |
Measured with a caliper -
front surface of the valve covers' timing pointer to rear outer-most surface of the
cam sprocket wheel = 0.6732inch (17.1mm)
belt width = 0.7141inch (18.14mm) _________________ "..it's made in Germany. You know the Germans always make good stuff."
jbwheele
Posted: Thu Feb 17, 2011 12:48 pm Post subject: Mines 16.5mm |
16.5mm.................. _________________ Joe
jbwheele
Posted: Thu Feb 17, 2011 12:50 pm Post subject: sorry wrong line on ruler |
16.7 give or take a mm _________________ Joe
jbwheele
Posted: Sun Mar 13, 2011 5:59 pm Post subject: Hey Ive Figured it out |
Hey Guys I think the answer to Belt to pulley position is the wear and position of the tensioner pulley, If you check for lateral play (wiggle hard)
I moved mine back onto the pulley more by grinding the seating surface of the tensioner pulley mount so that when it is in the Belt tightened position the pulley now sits more upward angel thus pulling the belt back.......dont go too far cause the belt will wear out on the flanges on the ends of the tensioner pulley
hope this helps someone........I will get a new tensioner pulley one day _________________ Joe
