Not starting need help????
tuf-924
PostPosted: Sun Mar 20, 2011 7:26 pm    Post subject: Not starting need help???? Reply with quote
Ay guys I'm Andrew v from australia I was driving in the wet last night and it was pouring down heavy, pulled up in a carpark car was idling for a while I took off on the high way and my car had no power wouldn't go faster then 30 km an hour I pulled up turned it off tried cranking it again wouldn't start towed it home tried adjusting the sensor bowl thingo for the air intake still nothing.
Would anyone know why it's not starting? Would be a massive help if anyone has any ideas at all.
Cheers
Vass...
924aussie
PostPosted: Sun Mar 20, 2011 8:16 pm    Post subject: Reply with quote
Can you give us more information about not starting as it stands NOW
Do you have FULL battery power
Does it try to turn over
Does it turn over but stops
anything else ?
alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
tuf-924
PostPosted: Mon Mar 21, 2011 6:12 am    Post subject: Reply with quote
It cranks but the engine won't fire the battery was alil flat but not completely it's on charge now.
But I checked for spark it has spark, checked fuel it's pumping fuel, all I can think of if it's off time but I was driving it before it failed I don't know why it would play up all of the sudden
Vass...
mikebola
PostPosted: Mon Mar 21, 2011 8:58 am    Post subject: Reply with quote
is your timing belt slack?
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
tuf-924
PostPosted: Mon Mar 21, 2011 3:22 pm    Post subject: Reply with quote
What do you mean by slack? You mean loose??
The alternator belt looks alil cracked and warn out, that wouldnt make the car not start thow would it?
Vass...
PostPosted: Mon Mar 21, 2011 8:55 pm    Post subject: Reply with quote
Had very similar problem.
Wife drove car out of shed, parked and hosed dust off.
Car wouldnt start afterwards.
Found fuse on extra fuse board burnt. Replaced and started straight away.
check fuses related to ign and fuel pump.
the electrics on these cars is common fault.
mikebola
PostPosted: Mon Mar 21, 2011 11:19 pm    Post subject: Reply with quote
the timing belt should be under a metal cover. it's a toothed belt. if it's loose, it can skip a tooth or two and cause lack of power and will be hard or impossible to start. the fuse box is a good thing to check out too.
