markmazour
Joined: 29 Sep 2008 Posts: 37 Location: Vermillion, South Dakota
Posted: Tue Apr 05, 2011 12:53 pm Post subject: Weltmeister Front Control Arm Bushing Torque |
Well I have finally gotten around to installing new Weltmesiter control arm bushings on my 1982 924. http://www.weltmeister.com/ProductDetails.aspx?productID=402 PB-1019 (along with new ball joints and wheel bearings)
After loosely assembling everything I got out my Haynes manual to check the torques. As I began torquing the front pivot bolt it dawned on as I saw the bushings begin to bulge that I was not going to get to the recommended 50 ft-lbs.
So my question here is how tight should these pivot bolts be with the Weltmeister bushings? Is there an alternate tightening method?
In retrospect I am beginning to wonder if i should have gone with the OEM bushings that have the steel sleeve. _________________ Mark
1982 Porsche 924 Indiana Red Metallic SOLD
2001 BMW 325i Silver SOLD
2011 BMW335is Space Gray 6mt |
Posted: Tue Apr 05, 2011 1:12 pm Post subject: |
Those Weltie bushings suck grande for the reason you have identified.
Search online for ProThane bushngs for Golf/Rabbit Mark I. Steel sleeve and all. . .should be sub $30. _________________ Toofah King Bad
Posted: Wed Apr 06, 2011 4:59 am Post subject: |
Part # is 22-201 _________________ Toofah King Bad
Posted: Wed Apr 06, 2011 5:54 am Post subject: |
Plus, the red is just stylish  _________________ Stefan
markmazour
Posted: Wed Apr 06, 2011 6:13 am Post subject: Control Arm Front Bushing Function/Torque Postulate |
I will use those the next time around but for now I'd like to use what I have already paid for. You are right the red bushings look pretty sweet in there. I am half tempted to have the calipers powder coated red.
Has anybody used these?
I suppose I could machine some sleeves using the dimensions from the old ones and then bore out
the Welts to accept the sleeve.
This brings a question to mind just for discussion purposes.
What part of this assembly should rotate and what should be fixed?
There exists three scenarios:
1. In the OEM version, a bolt, a steel sleeve molded into a rubber bushing, a steel control arm
and the steel cross member. In this case as the bolt is torqued to 50 ft-lbs the crossmember
flexes inward against the steel sleeve pinching it thus creating a fixed assembly. In which case
we have a scenario where the rubber bushing flexes around the steel sleeve, or the control arm
rotates around the rubber bushing.
2. A bolt, a sleeve, a poly bushing, a steel control arm and the steel cross member. Here again
as the bolt is torqued to 50 ft-lbs the crossmember flexes inward against the steel sleeve
pinching it thus creating a fixed assembly. In which case we have a scenario where the bushing
rotates around the steel sleeve.
3. A bolt, a poly bushing, a steel control arm and the steel cross member. In this case the bolt
cannot be torqued to 50 ft-lbs. It, in my best guess, should be tightened to the point that the
crossmember flexes inward and makes contact with the bushing. In which case we have a scenario
where the bushing rotates around the bolt or depending upon the fit the bolt in the bushing the
bolt rotates in the holes of the crossmember.
Or...am I missing the whole point here? Should the steel crossmember not flex at all under the
force of the 50 ft-lb torque. And should the fit of the steel sleeve between the torqued cross
member flanges be such that the sleeve rotates freely on the bolt? _________________ Mark
Posted: Wed Apr 06, 2011 8:05 am Post subject: |
The poly bushings rotate around the sleeve, which is trapped by the squeezing member (heh).
You're gonna machine sleeves, and then machine the Welt bushings just to make them work? To save $25?
Damn. _________________ Toofah King Bad
Posted: Wed Apr 06, 2011 9:27 am Post subject: |
Well, this is the 924board.
(goes back to work on the statue of Joe....) _________________ Stefan
markmazour
Posted: Wed Apr 06, 2011 12:08 pm Post subject: |
I have a background in Engineering and IT, not that IT has anything to do with this. But I have access to very talented tool machinists who are willing to trade machining services for drafting, engineering and IT services. And because of where I work I have access to a wide variety of materials that can be had at scrap rates of cents/lb, so... Anyway I have already spent too much money on the existing bushings to not use sleeved or sleeveless.
Rasta your response regarding the solid member, hehe, does make sense. But I wonder still wonder about the OEM? Any thoughts on that?
Not to be rude but now that we've had suggestions on alternate solutions does any body have an answer to the original question?
Ultimately I believe I will just use them as is and tighten both sides to a random, but equal, distance between the cross member flanges, where the clearance between the bushings and the cross member flanges would be zero. Basically start on one side and while shining a flashlight from behind my line of sight tighten the bolt until I cannot see light between the bushings and the cross member flanges. Measure with calipers and tighten the other side to that dimension.
This car is a Sunday driver/garage queen so I think I will be fine. _________________ Mark
Posted: Wed Apr 06, 2011 12:45 pm Post subject: |
| markmazour wrote: | | Rasta your response regarding the solid member, hehe, does make sense. But I wonder still wonder about the OEM? Any thoughts on that? |
Per FSM, the steel tube gets locked down when you torque it down. . .hence the commandment not to tighten until the wheels are bearing weight, so as not to preload the rubber, which is doing all the work when the arm travels.
| markmazour wrote: | | Not to be rude but now that we've had suggestions on alternate solutions does any body have an answer to the original question? |
I gave you the answer to your OP. The Weltie bushing, lacking a steel tube, is a POS for your early x-member, therefore DO NOT USE. Instead, pony up the $25 (both sides) on the Prothanes, since they have the REQUIRED steel tube.
| markmazour wrote: | | Ultimately I believe I will just use them as is and tighten both sides to a random, but equal, distance between the cross member flanges, where the clearance between the bushings and the cross member flanges would be zero. |
= suspension fastener with zero torque.
Please don't. _________________ Toofah King Bad
markmazour
Posted: Wed Apr 06, 2011 11:26 pm Post subject: |
Rasta: Per FSM? What is FSM? So Porsche relied on the flexibility of the rubber for rotation eh? Interesting.
Has anyone used the Welmesiter bushings that I have? If so, when installing them how tight did you torque the pivot bolts be with the Weltmeister bushings? Was an alternate tightening method? _________________ Mark
Posted: Thu Apr 07, 2011 12:12 am Post subject: |
FSM = Factory Service Manual.
Ditch the welties, get the prothanes, and be done with it! _________________ erstwhile owner of just about every 924 variant ever made |
jazz guy
Posted: Thu Apr 07, 2011 12:30 am Post subject: |
| markmazour wrote: | | Has anyone used the Welmesiter bushings that I have? |
I believe Mr. Rasta, who is trying to help you, does have experience with the weltie bushings. Their shortcomings have been discussed here and on other forums. That's why he's steering you to the prothanes.
Good luck with your suspension upgrade.
Cheers, Brian _________________ '81/'81/'82 |
markmazour
Posted: Thu Apr 07, 2011 12:46 am Post subject: |
And Mr. Rasta's advice is appreciated, seriously and will be followed. Either by purchasing the recommended parts or machining sleeves and boring the existing bushings.
I am only asking the original question now out of curiosity, what can I say I am an odd sort when something gets in my head....
I sent Weltmesiter an email I'll let you know their response if I receive one. _________________ Mark
jazz guy
Posted: Thu Apr 07, 2011 1:16 am Post subject: |
| markmazour wrote: | | ...what can I say I am an odd sort when something gets in my head.... |
I can appreciate taking a different route... have fun!
| markmazour wrote: | | ...sent Weltmesiter an email I'll let you know their response if I receive one. |
More Weltie info would just be superfluous... I have Prothane bushings installed already. Thanks, though!
