skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Wed Apr 13, 2011 8:45 am Post subject: How to remove vented nose panel |
What is the easiest way to remove this panel ? _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1976 911S Targa (Gone) |
Posted: Wed Apr 13, 2011 9:06 am Post subject: |
Next week I can take some pics of a car I picked up in Arizona last spring with the nose removed. He sawzalled most of it I recall, pm me next week. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Thu Apr 14, 2011 1:49 am Post subject: |
3/8 spot weld cutter and bit to drill pilot holes in each weld.
Remove bumper, open light buckets, remove headligt squeegees, remove 10mm bolts at the outside corners of the headlight openings.
Wipe down the seams, upper and lower. This will help you see the welds. Using cutting fluid, drill a pilot hole in the center of each weld then remove the weld with spot weld cutter. The last one I did took 30 minutes or so. _________________ Toofah King Bad
skytrooper
Posted: Sun Apr 17, 2011 3:54 am Post subject: |
Thanks ! _________________ Matt
1982 - BMW 633CSi
1984 - BMW 528e
Posted: Sun Apr 17, 2011 4:16 am Post subject: |
Is it really what you want to do cause there kind of a pita to reposition and reinstall.. Ask me I know. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
skytrooper
Posted: Sun Apr 17, 2011 5:07 am Post subject: |
It is on a car that I am parting out. _________________ Matt
1982 - BMW 633CSi
1984 - BMW 528e
