Refinish Door Handles
Clbmkr1
PostPosted: Thu May 05, 2011 2:23 am    Post subject: Refinish Door Handles Reply with quote
The door handles on my "80 931 are faded to grey. Is there a good method to bring back the black color?
I tried Mother's Back-to-Black; didn't do a thing for it.
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Thu May 05, 2011 3:22 am    Post subject: Reply with quote
What thats a no-brainer. Order new seals for nrxt to nothing,
pull the handles and refinish them & reinstall. if you sanded them
with some fine grit after poppping the plastic insert them squirte some paint on they should look as good as new.
Clbmkr1
PostPosted: Thu May 05, 2011 3:44 am    Post subject: Reply with quote
Well, put that way, it does sound like a no brainer.
I wondered if there wasn't some miracle stuff that would "wipe-on, wipe-off".
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Thu May 05, 2011 5:11 am    Post subject: Reply with quote
If there was we would be 'wiping on and wiping of'f our cars to avoid the expensive repaints
Clbmkr1
PostPosted: Thu May 05, 2011 6:14 am    Post subject: Reply with quote
A new paint job is reaching the top of the list. I'll hold until then to pull the door handles.
Thanks for the input.
Jim Baldwin
1980 931
2013 Lincoln MKZ
2013 Ford Escape
PostPosted: Sat May 07, 2011 5:03 am    Post subject: Reply with quote
I think the door handles are made of pot metal (or something not much better). I've not had very good luck with paint, as it chips very quickly, even after using etching primer first. I've been wanting to try powder coat, seems like it would be more durable.
PostPosted: Sat May 07, 2011 5:12 am    Post subject: Reply with quote
Wekll ya know what, thats right dan-man though why go thru
using all them products such as self etching primer...
Quicke solution any place will tell you is. The DIY method
get creative pop out the plastic inserts or leave them if there
discolored & nasty. Follow this with some good masking tape
a lil newspaper & spray some rustoleum on them ... try using there
stove/barbique paint if you looking for a pretty tough non-fading
non-gloss black.
