kcoyle
Posted: Fri Dec 23, 2011 2:58 am Post subject: Will these rims fit my 931? |
They are 951S Clubs Sport wheels 16 x 7 & 9, they are nearby and reasonably priced. Anyone know if they will fit without any major mods?
I think they will according to the below calculator. Maybe a little fender rolling?
Rear wheel difference.
Front wheel difference.
Pelican ad below
http://tinyurl.com/6t4epec
Thanks!
Kevin _________________ 1982 931- Stock with MBC at 8psi
Posted: Fri Dec 23, 2011 6:31 am Post subject: |
Fronts will not fit without spacers. Rears may fit depending on tire size. I have 225/50/16 on the back of mine, with fender lips flattened down, and I can BARELY get one finger between the tire and fender. _________________ Toofah King Bad
kcoyle
Posted: Fri Dec 23, 2011 7:58 am Post subject: |
| Rasta Monsta wrote: | | Fronts will not fit without spacers. Rears may fit depending on tire size. I have 225/50/16 on the back of mine, with fender lips flattened down, and I can BARELY get one finger between the tire and fender. |
So the fronts would need about a 1 inch spacer, and the rears may fit. Do your rears fit with typical alignment or with lots O camber? _________________ 1982 931- Stock with MBC at 8psi
Posted: Fri Dec 23, 2011 9:28 am Post subject: |
Regular camber (8x16, ET52.3). _________________ Toofah King Bad
kcoyle
Posted: Fri Dec 23, 2011 10:59 am Post subject: |
RM,
Thanks for the information, I think I'm going to pass on these wheels. I guess I really just want a straight bolt on set of d90's or (gasp) trashcans. _________________ 1982 931- Stock with MBC at 8psi
Posted: Fri Dec 23, 2011 11:21 am Post subject: |
Call Wheelenhancement.com. _________________ Toofah King Bad
Raceboy
Posted: Fri Dec 23, 2011 5:35 pm Post subject: |
Late offset wheels fit just fine on narrow-boady 924. I have late offset BBS RS (16x8 and 16x9) and Cup 1 (17x7 and 17x9) fit just fine on regular 5lug early 944 brakes. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
