Glass reseal
headstrong2740
PostPosted: Sun Jul 03, 2011 2:30 am    Post subject: Glass reseal Reply with quote
So i have been working on the car and bringing it back to life and is coming well...
The rear glass is coming unsealed at the top. I have looked around on here and found threads of others that have tried to reseal with some horrible results... so i feel i will leave it to the pros to do.
I found a shop here that will remove and replace the glass for 100, but if it breaks they can get new glass and have it in for $285
Does this seem really low to anyone?
IF SO... who else needs this done.. because i have a shop you should call to get it done at!! LOL
1987 924s "Enzo"
2002 1.8t VW Passat
http://porsche924resto.shutterfly.com/ - follow the progress of "Enzo"
joecitizennn
PostPosted: Mon Jul 04, 2011 6:34 am    Post subject: Reply with quote
You probably noticed this at the car wash. Most 944 hatches I have owned will leak at the top when sprayed from the rear with a high pressure wand, but when rained down on they do not leak. If the glass is not DETACHING from the frame I would attempt to seal it myself before handing a wad of cash to someone else.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
headstrong2740
PostPosted: Tue Jul 05, 2011 12:43 pm    Post subject: Reply with quote
oh no.. the glass is detaching.. and i can fit my fingers between it and the fram up on top... so it needs to go to be resealed....
this of course is the least of my new problems... new thread to follow in a few minutes
1987 924s "Enzo"
2002 1.8t VW Passat
dvalmont136
PostPosted: Wed Jul 06, 2011 9:35 pm    Post subject: Reply with quote
I have this exact same issue and wasn't sure what exactly I should do to try to fix. Any suggestions?
80 931 <RIP - Change your Timing Belt!>
88 924S Stock/Auto/SaratogaTop/WilksChip
12 FXT Touring
12 BMW E92 335i M-Sport
dally_de
PostPosted: Thu Aug 18, 2011 3:20 am    Post subject: Reply with quote
you should go to a autoglass service they can fix your problem (reseal ) ..or you could try to fix it...but from my opinion it's not worth it..
