Tyres
leadfoot
PostPosted: Sun Jun 12, 2011 7:30 am    Post subject: Tyres Reply with quote
I got some semi slick tyre withs the rims i purchased but am unsure if they are ok or not
The tread indicator is getting close and so theres not much time left on them at any rate, the potential issue is there are some cracks in the rubber on the main treads, some are large i.e 20cm long and 2 to3mm wide. They have been used on a 911 enthusiests track car. So i'm not sure if this is the result of running over some shrapnel on the track or tearing? Do more solid slick tyres do this?
Cheers stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
Andrew NZ
PostPosted: Sun Jun 12, 2011 9:08 am    Post subject: Reply with quote
My Dunlop semi slicks have all sorts of cuts and nicks in them. it doesn't take much with these things (stones will do it). Can you post a photo?
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
joecitizennn
PostPosted: Sun Jun 12, 2011 2:27 pm    Post subject: Reply with quote
Cracks in a rubber tire are not always a problem, it depends on what kind of crack and where. Bigger dangers are slipped belts and tread seperation. As Andrew NZ stated, a picture would be most informative.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
leadfoot
PostPosted: Sun Jun 12, 2011 3:05 pm    Post subject: Reply with quote
yep ok post up a pic next day or two
cheers
Stu
