tuf-924
Posted: Thu May 26, 2011 7:20 pm Post subject: Hot start kit?? |
Can someone help explain to me how to get the hot start kit and how to install it, I read the page about it but I dont get it.
Anyone who has done it could you help me out?? _________________ Vass... |
Posted: Thu May 26, 2011 9:14 pm Post subject: |
Did it once and then removed it.
Fix the problem, dont bypass it. _________________ Porsche 924 1984 (UK import) NA
Posted: Thu May 26, 2011 9:20 pm Post subject: |
Here's an excellent read to get you started on Ozzie's suggestion:
http://www.924board.org/viewtopic.php?t=28969&highlight=hot+start+kit _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
tuf-924
Posted: Thu May 26, 2011 9:38 pm Post subject: |
Ozzi how do I fix it?? _________________ Vass... |
leadfoot
Posted: Thu May 26, 2011 10:04 pm Post subject: |
| tuf-924 wrote: | | Ozzi how do I fix it?? |
| ideola wrote: | ideola"
FWIW, some time after I posted all this, I discovered a little tidbit in the owner's manual. It's Smoothie's infamous "depress accelerator BEFORE cranking" when the car is hot. I don't have the manual for the NA here with me or I'd quote it.
In any event, I started doing this, and the hot start problem has gone away. So I think my system is fine, I just needed to RTFM. Go figure!??
from this post
http://www.924board.org/viewtopic.php?t=28954&postdays=0&postorder=asc&start=0
also I do believe keeping the coolant temps low help, so a lower temp fan sensor and thermostat help, lastly an oil cooler is a great bit of kit.
carbon fiber GT mish mash
Posted: Thu May 26, 2011 11:20 pm Post subject: |
Everytime a CSV is hacked, a unicorn dies.
Why not repair the problem instead? _________________ Toofah King Bad
spannernut
Posted: Thu May 26, 2011 11:32 pm Post subject: |
i had a similar problem,very embaressing to say the least.was looking into getting a replacement unit,but by chance i noticed a leak at the rear of the car,got underneath and low and behold,the fuel accumulator was leaking.
fortunately i had a spare one,when i picked the spare one up i noticed it had a small screw in the bottom,so before i went about changing it i got under the car and took the screw out,cos thats where it was leaking from,anyway this might be helpful to some of you,i then got some plumbers tape and put a bit around the screw ,i then screwed it back into the accumulater ,and hey presto no more leak and starts easy from hot now
Rattlinbone
Posted: Fri May 27, 2011 2:06 am Post subject: |
| Quote: |
Stu |
I've been thinking about oil coolers. If I were to install an oil cooler on my toofah, would I also want a thermostat to go with it? I mean, I think it might be a good idea to have it so that the oil cooler would not turn on until the engine gets a little too hot. I mean, I wouldn't want the cooler to turn on while the engine is trying to warm up, I would only really want it on if the engine starts to get too hot, like in stop and go traffic on a hot desert day (and we get a lot of those around here!)
By the way, can anybody recommend a good oil cooler/thermostat set up for a 924 NA? _________________ Fred- 1979 924 |
Posted: Fri May 27, 2011 3:18 am Post subject: |
You do need a t-stat. . .without one, high OP on startup could pop your cooler. _________________ Toofah King Bad
Posted: Fri May 27, 2011 7:41 am Post subject: |
You are losing holding pressure in the fuel line.
Pressure should drop to about 20psi and stay there for several hours after shutdown.
This could be the non return valve in the pump (or on the pump), accumulator(s), pressure regulator in the CIS dissy, WUR or injectors.
The pressure regulator is a small 'o' ring in the CIS and the cheapest part.
Most of the remainder can be checked easily. _________________ Porsche 924 1984 (UK import) NA
Posted: Fri May 27, 2011 7:45 am Post subject: |
Location of regulator in ROW cars _________________ Porsche 924 1984 (UK import) NA
tuf-924
Posted: Fri May 27, 2011 6:17 pm Post subject: |
| spannernut wrote: | | i had a similar problem,very embaressing to say the least.was looking into getting a replacement unit,but by chance i noticed a leak at the rear of the car,got underneath and low and behold,the fuel accumulator was leaking. |
Yea that is my problem to when I full my car up with fuel it leaks from the left rear, I can't see where from though which is frustrating.
Ever since I noticed that my car has been playing up more and more _________________ Vass... |
tuf-924
Posted: Fri May 27, 2011 6:22 pm Post subject: |
| Ozzie wrote: | | Location of regulator in ROW cars |
Ok so that holds the pressure inside the dizzy? _________________ Vass... |
spannernut
tuf-924
Posted: Sat May 28, 2011 11:06 am Post subject: |
I just found a split in a fuel line, the line that connects to the very top if the fuel dizzy could that cause loss of fuel pressure? _________________ Vass... |
