Intermittent fuel pump
Ian89C4
PostPosted: Sun Jul 31, 2011 5:04 am    Post subject: Intermittent fuel pump Reply with quote
I tried searching for and answer to my question but my searching skills suck. I do not have the secondary fuel pump hooked up to the fuel pressure regulator but wanted to make sure my wiring fixes worked. I put around 2 gallons of fuel in the tank (had emptied it prior) so that the pump was not running dry. I stuck the hose into a fuel can and switched the key to the run position.
At first there was nothing and then I remembered I had not hooked up the grounds in the trunk. The pump didn't want to work at first, so I went to turn the engine over and it finally kicked the pump on. When I turn the key to 'on' the pump comes on put runs intermittently. Both pumps work and put out a good volume of fuel, but I am curious about the intermittent flow. Should the pump be doing this? or do I have an issue somewhere?
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
PostPosted: Sun Jul 31, 2011 5:56 pm    Post subject: Reply with quote
Normal.
Prevents pumping fuel when the engine is not running.
stevekat
PostPosted: Sun Jul 31, 2011 6:05 pm    Post subject: Reply with quote
When using the fuel pump relay, the relay shall not actuate unless it gets a pulse from the ignition. I believe this pulse occurs when cranking and running. It is a fail safe so that the fuel delivery system is disabled when the engine stops running when the car is in extremis due to a collision, rollover, etc. (and the engine stops as a result. It prevents fuel from continuing to flow.
"Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's.
Ian89C4
PostPosted: Sun Jul 31, 2011 11:21 pm    Post subject: Reply with quote
Awesome! Thank you guys.
Ian Edgerly
North Carolina
Current:
dpw928
PostPosted: Mon Aug 01, 2011 2:16 am    Post subject: Reply with quote
The pump runs when the ignition is turned on to prime the fuel system but it doesn't run during cranking, This is to keep the engine from flooding in a no start situation. When the engine is cranking the 50 circuit only is activated. The 15 circuit which controls the fuel pump relay is bypassed.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
