Rack Refresh
PostPosted: Mon Jun 27, 2011 6:23 am    Post subject: Rack Refresh Reply with quote
Just received a manual steering rack from the salvage yard. Turns nicely, but I still think I'd like to clean out all the old grease and regrease it. Anyone over done this? Recommendations?
Thanks!
tyfighter123
PostPosted: Mon Jun 27, 2011 9:07 am    Post subject: Reply with quote
Hey Rasta, I repacked my steering rack, there is a black plastic knob at the bottom of the rack that pushes in, it doesnt screw in. I removed that and turned the rack all the way to one side and cleaned out as much of the old grease as possible then turned back the other way and did the same. I repeated over and over then I packed new grease in and turned side to side again. I think you maybe be able to add grease through the bottom where the plug goes but I just replaced it with a new cap. Let me know how it goes.
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
PostPosted: Mon Jun 27, 2011 11:05 am    Post subject: Reply with quote
I did mine per the directions in the tech section here on the site and they were right on. A tapered bolt for centering the rack was handy and note the position of the bolt on the pinch clamp of the steering shaft with both the steering wheel and the rack centered before pulling out the pinion. You have to loosen the centering bolt when reinserting the pinion as the rack will move a bit as the pinion rotates in. It may take a time or two. Try not to ruin the pinion bearing like I did by forcing it in. Bearings available at any bearing house SKF 1012 needle bearing(I bought 2 if you end up needing one). I got a grease fitting with the right thread pitch for the centering hole at NAPA.
Mike
joecitizennn
PostPosted: Mon Jun 27, 2011 11:34 am    Post subject: Reply with quote
A good stiff bra will pick up a tired rack.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
PostPosted: Mon Jun 27, 2011 3:25 pm    Post subject: Reply with quote
2fah LOL
