BionicBalls
Joined: 05 Jan 2009 Posts: 642 Location: Charlotte, NC
Posted: Sat Jul 02, 2011 10:50 am Post subject: Exhaust keeps breaking |
My exhaust keeps breaking the welds loose at the catalytic converter. I've got headers and 2.25" stainless steel pipe all the way back. Magnaflow Hi flow cat and a flowmaster super 44 muffler.
I've got some popping in my exhaust when I decelerate. I'm pretty sure this is causing the welds to break loose.
I've got a flex pipe on the way, think this will absorb the vibrations caused by the exhaust popping?
I think the popping will lessen as soon as I set the A:F ratio correctly. _________________ 1980 924 NA
1982 931 |
Posted: Sat Jul 02, 2011 1:57 pm Post subject: |
No part of the exhaust system is attached to the body, correct? Are all your hangers from the CAT back intact? _________________ White 87 924S "Ghost"
BionicBalls
Posted: Sat Jul 02, 2011 8:08 pm Post subject: |
Not attached to the body at any point. All the hangers are intact and in good condition. That's what makes this so frustrating. _________________ 1980 924 NA
1982 931 |
leadfoot
Posted: Sat Jul 02, 2011 9:17 pm Post subject: |
how are your motor mounts then?
carbon fiber GT mish mash
Posted: Sun Jul 03, 2011 12:44 am Post subject: |
Time to try a different muffler shop? _________________ Toofah King Bad
Posted: Sun Jul 03, 2011 4:18 am Post subject: |
That is freakin amazing that the welds are breakin maybe adjust the afm
so it dont pop..
Good luck with the flex pipe.Ill bet its the fix. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sun Jul 03, 2011 6:21 am Post subject: |
Popping is probably from air leaking into the system from poorly sealed pipes/joints.
Try adding another hanger near the front of the exhaust and of course the flex coupling will help quite a bit.
Bad motor mounts will exacerbate the vibrations and make the exhaust more prone to cracking and breaking. _________________ Stefan
BionicBalls
Posted: Sun Jul 03, 2011 7:53 am Post subject: |
I adjusted the throttle body adjustment screw to let more air in and it has reduced the popping significantly. I had been told that the popping was due to the lack of back pressure from having headers and a larger exhaust piping. true? I'll be adding the flex pipe in and I'll see if I can't add another hanger as well.
Every time I've had a bad motor mount on a car before, I could feel the engine vibrating. That's not happening here, engine feels smooth. I Visually inspected the driver's side mount and it's not cracked or broken. The passenger side one is a shock type mount, how would I go about checking it? _________________ 1980 924 NA
1982 931 |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Tue Jul 05, 2011 1:49 am Post subject: |
you need 2 people one to drive car and one to hang on the hood...Just kidding!!apply parking brake,put car in first and let out clutch and have other helper look at mount and see if its sperated,put in reverse for other side edit ;if its automatic just brake torque in fwd and reverse _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
Min
Posted: Tue Jul 05, 2011 3:28 am Post subject: |
What kind of filler is your stainless exhaust system being welded with?
BionicBalls
Posted: Tue Jul 05, 2011 7:15 am Post subject: |
I'm tired of dealing with the muffler shop so today I did it myself. I unbolted the center section of my exhaust. I ground down all the welds and started from scratch. I cut out a section and fit in the flex pipe. Re-welded the cat. Bought a new header gasket and exhaust donut.
I removed the o2 sensor and set the A/F ratio there using my gunson. Still some popping, but alot less.
I've got a mig welder and I use what ever wire my dad buys for it. It is some good stuff. We bought some cheap shit once before, and it fed poorly, got poor penetration and ugly welds no matter how slow we fed it.
So far everything is sounding good, I'll report back in a week.
New problem is a pinhole in the seam of my overflow tank that's spraying a small bit of coolant everywhere. Tried plastic welding it, but it's not containing it. I'm going to try one more time, but may have to just replace it. _________________ 1980 924 NA
1982 931 |
Min
Posted: Tue Jul 05, 2011 4:40 pm Post subject: |
| BionicBalls wrote: | | I've got a mig welder and I use what ever wire my dad buys for it. It is some good stuff. We bought some cheap shit once before, and it fed poorly, got poor penetration and ugly welds no matter how slow we fed it. |
If you just welded stainless steel pipe with regular steel filler, then uh you may have some issues.
Stainless steel welding would require a matching filler material, typically a stainless steel alloy.
BionicBalls
Posted: Tue Jul 05, 2011 11:06 pm Post subject: |
Makes Sense. I'll look into it. Hopefully everything holds though. _________________ 1980 924 NA
1982 931 |
Posted: Wed Jul 06, 2011 6:22 am Post subject: |
The original exhaust used a hanger at the rear end of the downpipe that supports the downpipe and the front of the cat (and there was an adapter between the downpipe and the cat).
Does your header have that hanger? If not, the exhaust would probably break where you descibe over and over again. |
BionicBalls
Posted: Wed Jul 06, 2011 12:56 pm Post subject: |
My header does not have a hanger. That is going to be the next thing I do even if the exhaust doesn't break open again.
Thanks for the info gohim. _________________ 1980 924 NA
1982 931 |
