Z-Man
Joined: 06 Aug 2011 Posts: 3 Location: East Grand Forks MN
Posted: Sat Aug 06, 2011 5:15 pm Post subject: 87 924s fires and pops but won't start |
Ok here's the scoop been lurking here for awhile and read tons of posts but nothing to fix my issues. I purchased a 87 924 with the trans out supposed to run. put tranny in then it wouldn't start been through Clarks garage checked all I could think of so here I am. new computer, tack bounce plus both sensors ohmed out ok no scope also if either is disconnected the it quits firing ,35pis on fuel rail, new plugs,good relay, tried the jumper wire to, good ignition switch also tried the jumper wire, good coil, noid light says the injectors are working, vacuum tested the intake no leaks, took timing apart lines up right, good cap, good rotor, new starter I'm am not a automotive virgin but my first and maybe my last Porsche cranks fine and fires and pops but when the key is let go it all stops almost like the timing is to advanced backfires and stops the starter sometimes sorry if this seams drawn out I just want to get the most info out to stop the routine questions please help this thing may soon become target practice school is starting soon so I'm running out of time thanks Bill _________________ School Sucks Don't Ask |
Posted: Sun Aug 07, 2011 1:05 am Post subject: |
Sure you have the speed/reference sensors pulled into the right plugs? _________________ Toofah King Bad
Z-Man
Posted: Sun Aug 07, 2011 9:44 am Post subject: |
IT LIVES!!! HA HA HA HA!!! worked light right up don't know how they got switched I only undid one at a time but it's been sitting for about 4 years be for I bought it. thanks for the quick response now I can fill the trans and get it cleaned up thanks again Bill _________________ School Sucks Don't Ask |
Posted: Sun Aug 07, 2011 12:59 pm Post subject: |
Nice save Rasta!  _________________ White 87 924S "Ghost"
Posted: Sun Aug 07, 2011 1:01 pm Post subject: |
| Z-Man wrote: | IT LIVES!!! HA HA HA HA!!! worked light right up don't know how they got switched I only undid one at a time but it's been sitting for about 4 years be for I bought it. thanks for the quick response now I can fill the trans and get it cleaned up thanks again Bill |
And please change your oil, it is most likely full of gasoline. _________________ White 87 924S "Ghost"
Z-Man
Posted: Mon Aug 08, 2011 7:58 am Post subject: |
yup that's a natch don't want to wipe the cylinders _________________ School Sucks Don't Ask |
