B
Posted: Mon Jul 04, 2011 11:15 pm Post subject: question about brake pedal feel |
hi everyone
I guess this is kind of an extension of an earlier thread/problem I was having with the brakes
I have managed to get the brake pedal height to come up and to have much better firmness in the pedal.
When the car is started the pedal falls drastically (to me) - to probably less than 1/2 or maybe 1/2 pedal.
After a short time - 1 minute or less - the pedal returns to its original height before the car was started and appears firm again.
these things are started to drive me crazy - more than before
Does this sound normal for these brakes ?
thanks
Sean _________________ 1979 924 n/a
BAE turbo
5-speed snailshell |
Posted: Mon Jul 04, 2011 11:19 pm Post subject: |
Is the problem you are describing caused by a different amount of brake assist due to changing vacuum during warmup? How well are the brakes stopping your car?
It doesn't sound right to me, but I know that it can be very difficult to accurately assess brake pedal feel without actually driving the car. _________________ 78 924 NA
5-lug |
B
Posted: Mon Jul 04, 2011 11:25 pm Post subject: |
that was what I was not sure about - I had not driven the car for fear that they may fail I will do a small test in the drive to see how well they stop.
when I had the front on stands I spun the wheel and had someone apply the brakes and they seemed to work as did the rears
this just seemed really strange
thanks
BAE turbo
B
Posted: Tue Jul 05, 2011 2:01 am Post subject: |
driveway test seemed ok - I know it is not much of a test, but at least at 10 mph I know I can stop pretty well -
I will try to get it on the road today or tomorrow for a better test
thanks again
BAE turbo
B
Posted: Fri Jul 08, 2011 2:21 am Post subject: |
well after numerous speed bumps along the way - frozen adjuster and broken bleed screw being the last two, I finally put the car on the road for a short sputtering and chugging road test.
The pedal still feels somewhat soft and I am not sure I could lock them up - I hope I do not have to - The brakes do stop the car in a reasonable distance
There appear to be no leaks, the rears are adjusted to drag at 2-3 clicks and completely stop at 4-5 clicks and at least 2 qts of fluid have been bled through the system. Hopefully I am not missing anything. If the softness or mushy feel seems to become bothersome, perhaps I will need to look into master cylinder . ? .
Does this sound like I have done this somewhat correctly? Or does the pedal for your cars seem more rock hard - similar to a disc brake set up?
Thanks again
Sean B _________________ 1979 924 n/a
BAE turbo
Posted: Fri Jul 08, 2011 3:34 am Post subject: |
Large brake pedal travel can be caused by what's known as "knock back," which is when the brake rotor opens a brake caliper. This can be cuased by loose wheel bearings, but in a properly maintained car, can come from flexure of the spindle.
Long travel could be from this.
Or, there could be a stubborn bubble somewhere in your car.
Or, you could have a flexy rubber brake line that is causing your spongyness.
Or, another possibility is that your brake shoes aren't bedded in to the diameter of your brake drum, and what you are feeling is flexing of the brake shoe.
Could be lots of things.
Normally, a mastery cylinder needs replacing/rebuilding when the seals leak. This manifests itself by having a certain pedal pressure (fairly light) where you can push the pedal to the floor. Push harder and the seals stop leaking and the pedal gets hard. The pressure is usually around what you would use to stop rolling when at a stop light, so the brakes are doing something at that point. _________________ 78 924 NA
5-lug |
B
Posted: Mon Jul 11, 2011 6:52 am Post subject: |
thanks again
when I begin to apply the brake, I feel them begin to work - so they are working to a certain degree, I do not feel the hardness, after a point that I guess I expected to feel.
I checked the rotor after I put it back together for any movement side to side and did not have any - unless I was not pushing hard enough ?
I did replace the rubber hoses with stainless
I think i cleaned all of the grease off of the rotor when installing
I suppose it could be another bubble - they sure seemed to come pretty clean of those
Is there a time for new shoes and pads to bed (?) or seat themselves?
thanks again
BAE turbo
