headstrong2740
Posted: Tue Jul 05, 2011 12:51 pm Post subject: BLOW BY!?!?! |
So i had an interesting event happen yesterday... well.. actually a few days ago and then again yesterday.
The car has had some massive improvments made to it.
The head for starters you all knew about
Its also had the coil replaced, new wires, new cap, new rotor, new injectors, and is running very well.
But.. i jumped on it the other day and got it to about 4500 to 5000 rpm and noticed smoke... let off.. and it quickly dissapeared and did not come back under normal throttle.
I parked the car and opened the hood to find oil on the side of the motor and coming out of the oil fill tube.
My buddy and i talked it over for a bit (he is a former 944 owner) and we came to the conclusion quickly that i had ring problems.
I did a compression test and found the following results:
Cylander 1: 128
Cylander 2: 145
Cylander 3: 150 at this point i was excited that it might not be my rings.... might being the key word of course
Cylander 4: 83...... yes 83
so to make sure it was the rings and nothing else.. i added two small cap fulls of oil into .. and did it again.. this time it was 150... my rings were junk
so now i have to tear out the pistons and replace them.. and hope thats the only thing i replace.
Now i need some input:
what else should i replace while in there... i figure do the rod bearings would be a good things to do as well.
also who and where are the best price rings (cheap but good quality).
When it rains... it pours...this is the newest thing to come up and if you recall the link from my Finally Home thread there is more on there to tell you about it.... need to post more pics on it as well
Thanks in advance for the tips... ill need them soon to get the car going again... its becoming my daily driver and need it running soon. The fiance is driving the VW _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
http://porsche924resto.shutterfly.com/ - follow the progress of "Enzo" |
headstrong2740
Posted: Tue Jul 05, 2011 10:59 pm Post subject: |
also i ment to ask this as well...
Can you just tear apart the bottom and pull the pistons out that way and put them back in....
This way i can avoid tearing apart the top again since its all new and just been replaced.... ill have to tear apart the timing again and put in almost all new FOES... well some _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
Posted: Wed Jul 06, 2011 12:46 am Post subject: |
The head will need to come off to assess the bores, so you might as well pull the motor. Frankly, with compression that bad, I don't have high hopes for the block. _________________ Toofah King Bad
headstrong2740
Posted: Wed Jul 06, 2011 4:29 am Post subject: |
rasta... are you refering to the block being bad as in cracked.. or needing to be bored out...or what else?
cant you check bore through the bottom as well?
im trying to avoid an engine pull and all since i do not really have garage space to use at this time and dont know if i could get space at this moment _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
headstrong2740
Posted: Sun Jul 10, 2011 9:45 pm Post subject: |
Well i have come to accept the engine pull and have been shopping around for the parts....
I will begin tear down here shortly it seems and will check the whole block over before i get to ordering parts.
The strange thing that i still cant figure and would like some advice on
I would think that with that bad of compression in one cylander that the car would run like complete cr@p, but thats the thing.... the car runs hard and strong.
I even poured oil in the cylander and check compression to verify it was my rings... and with the oil, the compression shot up to 150. So i know its my rings
Any ideas on why its running so well even with the massive blow by?
Also Rasta, what were you refering to with the issue with the block? Was this in ref to the cylander being damaged or badly worn?
I will be mic-ing everything to make sure its all good... and ordering off the results... Ill keep you guys informed and any advice or feed back is more than welcome  _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
edredas
Posted: Mon Jul 11, 2011 3:46 am Post subject: |
| headstrong2740 wrote: | | I would think that with that bad of compression in one cylander that the car would run like complete cr@p, but thats the thing.... the car runs hard and strong. |
I had 60psi on cylinder #2 the first time I did a compression test on my motor. The car wasn't misfiring and ran perfectly fine which baffled me. I went and bought a two piece compression tester; (the kind that you can use a socket to install) then tried the test again. This time all the cylinders were in the 180 psi range. It turned out that the first compression tester wasn't seating tight enough.
| headstrong2740 wrote: | | i jumped on it the other day and got it to about 4500 to 5000 rpm and noticed smoke... let off.. and it quickly dissapeared and did not come back under normal throttle. |
My car was doing this, I fixed it by changing the fuel pressure regulator. _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
joecitizennn
Posted: Wed Jul 13, 2011 10:57 am Post subject: |
I will sell you a parts car with a good motor minus head for 500. All to have to do is pull the motor and put your head on it. Saves you time and money. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
headstrong2740
Posted: Wed Jul 13, 2011 1:24 pm Post subject: |
joe is that car a manual?? and what is the condition of the rest of the car? you have my attention full on for it and might take you up on it
year and model??? LOL _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
headstrong2740
Posted: Thu Jul 14, 2011 1:48 pm Post subject: |
Let me know soon on that car joe.. I might come down early next week and look at it and maybe pick it up.
Also... this thursday i will be starting the engine removal process.
I will be honest.. I started to read the manual on the engine removal process and surprised me that i would need to remove the rack and pinion it seems.
Any tips on the removal of the engine i should be aware of?
I plan to have the engine out in a day if i can if no glitches come my way. _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
joecitizennn
Posted: Sun Jul 17, 2011 10:59 am Post subject: |
Oh crap, I forgot I made this post and have not checked the board in a few. I will pm you my phone number. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold |
headstrong2740
Posted: Mon Jul 18, 2011 8:48 am Post subject: |
Its ok.... i was patient lol
"why has he not responded??? its been like two days?!?!"
2002 1.8t VW Passat
headstrong2740
Posted: Tue Jul 26, 2011 12:32 am Post subject: |
Well i picked up the parts car from joecitzen.
This parts car is a 84 944 with a solid setup and interior for most part is there... some wear and tear and what not
The plan is this as of right now:
To save the effort of pulling two diff. motors and building one solid one out of them and then putting it back in was to trasnfer everything over to the 944 and build it up....
This ment bringing the 924 down to a parts car... and stripping out what i needed. Sounds like a lot of work.. but in all reality a few good solid days of work would have it done
The first thing to do though is to get a title for it since it did not come with one...... no biggie right?
I started to look for the VIN so i could track down the title and get it switched over..... but this is where the problem comes in... and its not joecitzens fault... so dont start blaming him on this.. LOL
The placard on the drivers pillar is gone..... hmmm.. ok.. so i look for the sticker on the driver side up by the windshield and fender... its there.. but the corner where the VIN is... is ripped off... only the first two numbers are there.
The next number is the one on the battery compartment on the fire wall.... hmm there is an odd cut out.. oh wait.. the stamped number there is cut out and gone.... very odd
The next and last spot i knew of was the sticker in the trunk that has the option codes on it... also has the VIN... yep.. thats gone too
Is there any other places that the vin or the original stamp would be? By original i mean the one the car gets prior to coming over here and recieveing a domestic VIN.
Ill be cheking with the DMV tomorrow to see what my options are on this...
Otherwise.. ill be doing some massive body work and bringing the 944 fenders on to the 924s.. I really really like the way the 944 looks LOL
Let me know what you guys know cause im not having much luck on the internet trying to find any info. _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
Posted: Sat Jul 30, 2011 2:07 pm Post subject: |
Why mess with the 944 parts car at all? It's a parts car.
The reason that the ID Numbers are all missing could not be good.
The number by the battery was not the US VIN number, it was more like the Porsche Production Number. The US legal number was the one up on the windshield post.
If the parts car was mine, I'd take off the usable parts, and call a scrap guy to come take the rest.
Why take a chance that could stir up trouble, and cost you more than the parts car cost you?
Oh, and good luck mixing parts. You're going to find that the 84 engine block (while rated the same HP as the 87) is a completely different engine from the 87 engine block. You need to be careful when you assemble the 84 block to the 87 head. There were numerous engineering changes between the 84 engine and the 87 engine. Watch out when ordering parts, I don't know which parts are compatible, and why there are different replacement part numbers for some 84 and 87 internal parts. Which I found out when I went to find a replacement block for my 87 924S. I started with an 83 block. After stripping it down, and doing some research, sold it, and bought a 84 944 parts car. I parted that car, and kept the engine. After doing more research, I sold that engine, and bought a 87 944 engine with a broken belts, and the spring tensioner. I sold the head with four broken valves, planning on using my 924S head, as it only had 72K miles on it when the PO ran through a puddle in the rain and hydrolocked the engine, destroying the block.
From experience, I know that Porsche changed the head design, at least three times, and some variations are more desirable than others. There are also some differences in the cam tower assemblies, and some of them are more desirable than others as well. Buying, and selling engine parts to get to where I think I want to be, I've come across people looking for specific part numbers on the blocks, heads, cam towers. I don't remember what the people told me the differences were, but I do believe there was a method to their madness, even as I went from block to block myself. |
headstrong2740
Posted: Sun Aug 14, 2011 11:46 pm Post subject: |
this is very interesting that the blocks are different and all. I have yet to notice an issue with block or anything.
The head look like it should bolt up just fine and not have an issue...
your post has made me nervous and am now looking to see if there are diff. in the setup.
The parts car is acctually up for sale again as s parts car and is available if anyone wants it.
The motor itself is almost done, the lower end is built back up and the top end is about to go back on. So far, i have not seen an issue with diff. in the motor swap. Even sitting next to eachother they look the same.
Oh well.. im sure if there is a diff... i will see it here shortly when i go to put the top end back on.
if thats the case.. then ill be selling a very nice top end here soon. LOL _________________ 1987 924s "Enzo"
2002 1.8t VW Passat
