Posted: Wed Sep 21, 2011 3:49 pm Post subject: Wastegate |
Man what a King size PITA this was to get out... Took over 45 minutes to unscrew the top bolt on the bracket that
goes around the torque tube..
using a 13 mm box end and my fingers.
 _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Nein37
Joined: 29 Dec 2009 Posts: 513 Location: New London, CT
Posted: Thu Sep 22, 2011 12:10 am Post subject: |
Thats why my WG sits without its bracket.  _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Posted: Thu Sep 22, 2011 12:50 am Post subject: |
| Nein37 wrote: | Thats why my WG sits without its bracket.  |
Not good. I'm sure you know this, but you're asking for a cracked flange at the dump pipe and one or the other end of the j-pipe.
Hmm. I don't recall it being so hard to deal with upon installation...but maybe it's because I was working with all new hardware??? _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Sep 22, 2011 1:07 am Post subject: |
It's not. . .you usually leave the u-bolt in place and unbolt the assembly from it (unless it needs replacement). _________________ Toofah King Bad
Posted: Thu Sep 22, 2011 3:42 am Post subject: |
The worst that i did was not going by the book and pulling the trans & t - tube back to drop the motor nonno i have a nice big 1 1/2 ton engine hoist and tried to pull it out the top. _________________ 1979 porsche 924 Na
Last edited by Joes924Racer on Thu Sep 22, 2011 12:07 pm; edited 1 time in total |
Posted: Thu Sep 22, 2011 4:35 am Post subject: |
If you remove the K-member you don't have to pull the TT back. _________________ Stefan
Nein37
Posted: Thu Sep 22, 2011 6:11 am Post subject: |
| ideola wrote: | | Nein37 wrote: | Thats why my WG sits without its bracket.  |
Hmm. I don't recall it being so hard to deal with upon installation...but maybe it's because I was working with all new hardware??? |
Yup its on my list of things to do. I need to source another bracket though... mine was broken. _________________ 1981 931 CGT replica, OEM CGT intercooler, .8 BAR WG spring, GTS Headlights, Innovative Wide band A/F, A/C delete, 16" Fuchs, Weltmeister 200lb lowering springs, Bilstein HDs front, Koni Sport rears. |
Posted: Thu Sep 22, 2011 7:07 am Post subject: |
Which part do you need? The C clamp deal for the torque tube, or the flat piece that bolts to the wastegate? I might have a spare or two in my stash... _________________ erstwhile owner of just about every 924 variant ever made |
stevekat
Joined: 19 Jan 2008 Posts: 719 Location: Los Angeles, CA
Posted: Thu Sep 22, 2011 2:37 pm Post subject: |
Definitely use the bracket, or a cracked J-Tube is inevitable. It may even occur with the bracket. Suggest bolting everything together, than tightening up the bracket and/or torque tube clamp, so the brackets don't put stress on the assembly. I recall that removing the heat shield helps with access.
There is a heavy-duty upgraded bracket that superseded the original, and actually a clamp that bridges and connects the J-Tube and exhaust pipe, I think, that reduces vibration. _________________ "Never get out of the boat. Absolutely goddamn right. Unless you are goin' all the way."
Gone to new home: '81 924T, US version, CGT Intercooler, UTCIS-PT, Euro DITC, Greddy Trust MBC, Forged Fuchs Flat Dish 6's, Factory Recaro's. |
Posted: Thu Sep 22, 2011 8:27 pm Post subject: |
Or put an expansion / flex coupler in the j-pipe, like this:
