torque tube
bgammie1
PostPosted: Thu Sep 29, 2011 10:03 pm    Post subject: torque tube Reply with quote
at low speed while making left turns I get a groveling noise, is that the torque tube causing the noise.
If so, what does it take to correct the problem?
BFG
1982 Porsche 924 NA
PostPosted: Thu Sep 29, 2011 10:15 pm    Post subject: Reply with quote
Not likely to be the torque tube if it only does it while turning. Maybe a wheel bearing???
PostPosted: Fri Sep 30, 2011 12:34 am    Post subject: Reply with quote
I should like to hear a clip of this "groveling" noise... j/k
PostPosted: Fri Sep 30, 2011 2:16 am    Post subject: Reply with quote
The groveling sounds like this:
"PleasefixmeorIllbreakPleasefixmeorIllbreakPleasefixmeorIllbreak..."
I'd guess wheel bearing or CV joint.
!tom
PostPosted: Fri Sep 30, 2011 4:28 am    Post subject: Reply with quote
Brake line rubbing on the tire?
78 924 NA
5-lug
bgammie1
PostPosted: Fri Sep 30, 2011 6:38 am    Post subject: Reply with quote
think I figured it out, alternator hitting against the frame.
Looks like I need new grommets and mounting bracket (goes next to water pump on front of engine) has 2 bolt holes and the mounting / pivot hole which is wallowed out.
BFG
1982 Porsche 924 NA
PostPosted: Sat Oct 01, 2011 1:48 am    Post subject: Reply with quote
Sheesh, I'm at the wrong end of the car...DK why I thought this was at the rear...
