Custom manifold for 951 intercooler
Dutch924-racer
PostPosted: Tue Aug 30, 2011 5:50 pm    Post subject: Custom manifold for 951 intercooler Reply with quote
I am going to mount a 951 intercooler on my 931 (with cis).
What will be better, cut an original manifold an modifie it or build a new manifold ?
I used the search but I can only find custom manifolds for EFI/951 intercooler combination.
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Tue Aug 30, 2011 7:14 pm    Post subject: Reply with quote
build a new one.
Shurick
PostPosted: Tue Aug 30, 2011 7:16 pm    Post subject: Reply with quote
Here's a link FMIC+CIS setup, thanks to Dan for sharing.
https://picasaweb.google.com/111470514161382354517/UK931WithFMIC
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
PostPosted: Wed Aug 31, 2011 12:14 am    Post subject: Reply with quote
Or this one with stock inlet manifold http://picasaweb.google.com/111470514161382354517/Intercooled931InNZ?gsessionid=prwLNFSQvZYPqc5CoFQleA
Consensus is that a custom intake manifold will work best if you want to shorten/improve the line between the 951 FMIC and cylinders
PostPosted: Wed Aug 31, 2011 12:53 am    Post subject: Reply with quote
Flosho's custom built approach (from this thread):
-nick's modified / customized approach (from this thread):
My modified / customized approach (from this thread):
There are several others documented here on the forum, which you should be able to dig up with some searching...
WEASEL149
PostPosted: Thu Sep 01, 2011 4:16 am    Post subject: Reply with quote
I like all those approaches.
I do fancy having a go at making one like Ideola's with a spare manifold I have.
1979 UK 932
PostPosted: Fri Sep 02, 2011 1:24 am    Post subject: Reply with quote
3 fabbers competing ! awesome now who wants some leverage to say which is best.
PostPosted: Fri Sep 02, 2011 5:45 am    Post subject: Reply with quote
+1
I have a man lined up already to do this.
Dan, any feedback on this set up?
PostPosted: Fri Sep 02, 2011 5:49 am    Post subject: Reply with quote
Sadly, it's not in use yet, as the Ultra Wide Body project is on the back burner until I complete the Club Sport. But it was fairly easy for my welder to fabricate, and I'm very optimistic about how it will function.
PostPosted: Fri Sep 02, 2011 12:26 pm    Post subject: Reply with quote
I also like the ideola manifold. . .might move the add-on portion up flush, though.
Dutch924-racer
PostPosted: Sat Sep 03, 2011 5:23 am    Post subject: Reply with quote
This one also looks nice and I think the used a stock manaifold, but it is hard to see.
937 trackday car
Series 2 engine
Fast road camshaft
PostPosted: Sat Sep 03, 2011 5:31 am    Post subject: Reply with quote
If you do that, you'll have to rotate the throttle body 90 degrees and mount it sideways, along with fabbing up a custom throttle body bracket & assembly. With the TB so far forward, the diffuser plenum has to be down on the side of the manifold to avoid interfering with the closed hood, which is much lower that far forward than where the main plenum sits.
flosho
PostPosted: Wed Sep 07, 2011 4:07 am    Post subject: Reply with quote
If anyone wants to pay for it, I'll certainly have my manifold flow tested...
Otherwise I'm going to wing it - sorta.
[This Space For Rent]
Dutch924-racer
PostPosted: Fri Sep 09, 2011 3:26 am    Post subject: Reply with quote
I also like this one:
937 trackday car
Series 2 engine
Fast road camshaft
MillsMotorsport
PostPosted: Wed Nov 30, 2011 9:04 am    Post subject: Reply with quote
Has anyone tried a modified Audi/VW 1.8T inlet manifold and the cyl head flange plate from the 931? I guess the question is, how far apart are inlet ports on both engines? Are they close? Do they line up?
