Air regulator
Julian
PostPosted: Fri Dec 09, 2011 9:45 pm    Post subject: Air regulator Reply with quote
Where is, or what fuse, covers the lead to the Aux. Air Regulator? Should that lead have 12 volts during all the engine opperating time?
Thanks
PostPosted: Sat Dec 10, 2011 12:21 am    Post subject: Reply with quote
Yes, it should; not certain as you didn't post your year and model, but usually that's powered off the same fuse as the fuel pump, and also shares the power connection with the thermo-time switch/cold start valve and the control pressure regulator.
Julian
PostPosted: Sat Dec 10, 2011 12:35 am    Post subject: Reply with quote
Thanks, it's a 78 924. I traced it to the cold start. If they are both on the same line would explain some starting issues, Other than the fuel pump runs correctly. I don't see where there have been any extra wires run to the fuel pump. Only fuse blown is to some interior lights. Could that be on a relay?
PostPosted: Sat Dec 10, 2011 3:26 am    Post subject: Reply with quote
More likely broken wiring.
