Engine Removal...
garyj19
PostPosted: Mon Dec 05, 2011 12:31 am    Post subject: Engine Removal... Reply with quote
I am about to start the motor removal process... should be fun. I need motor mounts, rings, bearings, oil pump so she's coming out.
My question is, due to laziness, can I take the motor out without removing the transmission? it looks like i have a good 6 inches in front of the motor to slide it forward, is that enough to disconnect the clutch or just wishful thinking?
early 77 924 na
joecitizennn
PostPosted: Mon Dec 05, 2011 2:20 am    Post subject: Reply with quote
At least on the 944 and 924s the front crossmember must be dropped to slide the motor forward for removal.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
the_mad_electrician
PostPosted: Mon Dec 05, 2011 3:23 am    Post subject: Reply with quote
The 2.0 liter also requires removale of the crossmember. The oil pan is much closer to the crossmember then the distance required to clear the clutch/pressure plate.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
tyfighter123
PostPosted: Tue Dec 06, 2011 3:26 am    Post subject: Reply with quote
The first time I took my engine out I did it with both the tranny and crossmember in but it took FOREVER and I had to use pry bars. I would say as mentioned above to remove the crossmember and it will be much easier.
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 924S 1987 (parts car)(cut up and recycled)
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
garyj19
PostPosted: Wed Dec 07, 2011 11:26 am    Post subject: Reply with quote
Thanks guys, i hope it comes off quicker than my transmission would because thats how i would do it otherwise
early 77 924 na
Jakkq
PostPosted: Thu Dec 08, 2011 3:45 am    Post subject: Reply with quote
What is the usual cost for rebuilding one of our NA 924's? I really do want to pull my engine. I have oil leaks, and oil sitting everywhere I cannot get to, and I only keep wondering what else is wrong in there.
What is the usual time for pulling the engine? Would make a great winter project here, or seeing as how I am am currently almost finished with my 1st year of Automotive Technology, to take the engine into my 2nd Year class when the time rolls around and rebuild it there as a great starter engine to work on.
1979 Porsche 924- Snailshell
http://porsche924workblog.blogspot.com/
