CabooseSA
Posted: Sun Dec 18, 2011 5:31 pm Post subject: Why won't my ignition turn? |
I have started and used the car a few times today and no problems. Then tonight, all of a sudden, the key would not turn the ignition. In the past I've been met with resistance, but I just try a 2nd time and it works. But this time, the key would not turn the ignition.
I read online that sometimes when the steering wheel locks the key won't work, and they said to pull the steering wheel while turning the key. That doesn't work, and the only way I could turn the key was if I tapped the cylinder with a hammer while turning it. But after the 4th or 5th time of that, the key won't turn past half way, and I can't start the car because of it.
I was hoping someone would know what to do or be able to help. Any input would be greatly appreciated! |
Posted: Mon Dec 19, 2011 2:03 am Post subject: |
This is usually caused by sticking tumblers. Try some graphite powder. _________________ White 87 924S "Ghost"
joecitizennn
Posted: Mon Dec 19, 2011 3:32 pm Post subject: |
also aftermarket key blanks are often softer than the original keys and the shape changes as they wear. After a while they can stop working on certain tumblers for no apparent reason. Would be interesting to know if you have the original key or a copy. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
nwns
Joined: 27 Sep 2008 Posts: 93 Location: Lancashire, UK
Posted: Tue Dec 20, 2011 8:53 pm Post subject: |
Only takes 20 mins or so to whip it all off, easy enough to get the barrel out if it's pre-drilled and I can give you exact locations to drill if it hasn't. _________________ Pete |
CabooseSA
Posted: Sat Dec 24, 2011 3:51 am Post subject: |
| It is an aftermarket key because the original was lost while moving. I have read about graphite powder working and am trying that soon. I have managed to get it starting my hitting a "sweet spot" on the bottom of the steering column right under the ignition. That works every time, but isnt exactly a permanent solution |
