924aussie
Joined: 02 Feb 2006 Posts: 1009 Location: Chinchilla Queensland Australia
Posted: Tue Jan 10, 2012 1:23 pm Post subject: looking for the name of a tool used to copy angles and curve |
I am looking for the name of a tool used to copy angles and curves. I had a metal tool that you were able to place against an object and it reproduced the curve or shape of the object that you could then take away to duplicate it .
The best way I could describe it would be to say it was a short ruler that had sliding pins that stuck out on both sides. When you placed it against a coke can for example , the can would push the pins out the other side in the shape of the can. There was a toy that would do the same if you pushed your face into it, it would show your face in 3D looked like a lot of little nails.
Have googled many different things but still cant find it.
Alan _________________ green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Tue Jan 10, 2012 2:34 pm Post subject: |
Dressmakers use a thing called a "spline" which is basically a length of lead encased in rubber. It is used for tracing curves on a pattern for copying onto another sheet.
Wade. |
924aussie
Posted: Tue Jan 10, 2012 4:19 pm Post subject: |
That one is also known as a Flexible drafting curved ruler, found that one
the_mad_electrician
924aussie
Posted: Tue Jan 10, 2012 7:53 pm Post subject: |
Thats the one , thank you very much
924aussie
Posted: Tue Jan 10, 2012 9:53 pm Post subject: |
Found the motorsport one now as well
peterld
Joined: 10 Dec 2006 Posts: 984 Location: Noosa Heads QLD Australia
Posted: Tue Jan 10, 2012 10:31 pm Post subject: |
Normal contour guages available at most hardwares, certainly at Bunnings.
Pipe style one very interesting - if you find one of those in OZ do let us know. _________________ 80/81 932/8 ROW |
924aussie
Posted: Tue Feb 21, 2012 11:59 pm Post subject: |
| peterld wrote: | Normal contour guages available at most hardwares, certainly at Bunnings.
Pipe style one very interesting - if you find one of those in OZ do let us know. |
Getting a quote now from OS about 40 USD just checking on postage
http://static.speedwaymotors.com/pdf/910-86125.pdf
http://www.speedwaymotors.com/Pipemaster-Contour-Gauges,9698.html?parentDisplayId=8260
or I could make a bigger one of these and do the whole 924
