Fuel distributor help please!!!!
Mexico924
PostPosted: Thu Mar 22, 2012 3:29 am    Post subject: Fuel distributor help please!!!! Reply with quote
Hello every one, I went trough cleqning and replacing all the o rings of my fuel distributor. Nevertheless, i found thet one of the little filters that go below the banjo bolt of every line of the injectors is missing.
Are they needed, can I live with taking all of them out???
Does some one has one or a set I can buy or nows a place I can get a replacement?? (the lillte filter)
Thnaks a lot
I look forward to your feedback
Regards
Eduardo
1977.5 924 NA
1971 911 T sunroof in restauration process
1962 356 notchback (sold)
Ian89C4
PostPosted: Thu Mar 22, 2012 6:48 am    Post subject: Reply with quote
Hey Eduardo!!
Welcome!
I do not believe that you need them, however.....
I would make very sure that you have a brand new fuel filter installed prior to pressurizing the fuel system, and I would ensure that you are running top grade fuel.
The little screens are the final step to keep small particles from getting into the fuel distributor. Seeing that you have already taken the distributor apart (good for you, I could not get mine to seal back up and had to buy another one) you have seen all the tiny fuel passage channels in the thin metal plate between the two halves. Wouldn't take much to clog them.
If you are willing to take the chance, then you should be just fine.
Ian
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
SilverGhost
PostPosted: Thu Mar 22, 2012 8:33 am    Post subject: Reply with quote
Ian89C4 wrote:
The little screens are the final step to keep small particles from getting into the fuel distributor.Ian
I think he's talking about the screens at the upstream ends of the injector lines, which stop particles getting to the injectors, not the fuel distributor.
My guess is that they're nice to have, but that the preceding filters would generally stop most particles before they reached that point.
"Priscilla" 1981 924 NA RoW auto, metallic blue
Mexico924
PostPosted: Thu Mar 22, 2012 12:51 pm    Post subject: Reply with quote
thanks,
I will instal it tomorrow and hope that wil work find
you were very helpul
thanks again
Eduardo
1977.5 924 NA
Mexico924
PostPosted: Thu Mar 22, 2012 12:57 pm    Post subject: Reply with quote
I appologize for my spelling, I will be more carful next time
Thanks again
Eduardo
1977.5 924 NA
Ian89C4
PostPosted: Fri Mar 23, 2012 2:39 am    Post subject: Reply with quote
silverghost:
good point, for some reason I had it backwards in my head....been away from the car too long and starting to forget stuff already
Sorry about that Eduardo, hope I did not confuse anything
Ian
Ian Edgerly
North Carolina
Current:
Mexico924
PostPosted: Fri Mar 23, 2012 2:55 am    Post subject: Reply with quote
Thanks Ian
No the idea was clear, i got it right.
Thanks a lot
Eduardo
1977.5 924 NA
