So it doesn't have a collapsible steering column...
staticsan
PostPosted: Sat Mar 03, 2012 10:08 am    Post subject: So it doesn't have a collapsible steering column... Reply with quote
Without pulling it apart, the engineer could not find evidence the steering column in my 924 is collapsible. Which means it isn't an engineering pass.
If I pull the wheel assembly off, what specifically am I looking for? He said if I could do that and show the collapsing section, he could pass it. Alternatively, there were some here who said a few month ago that they were happy to send me one. It's not hard to change over, is it?
Wade.
BionicBalls
PostPosted: Sat Mar 03, 2012 10:45 am    Post subject: Reply with quote
stock 924 steering does have collapse section in the steering wheel as far as I know. Aftermarket hubs such as MOMO do not.
1980 924 NA
1982 931
924aussie
PostPosted: Sat Mar 03, 2012 10:57 am    Post subject: Reply with quote
Can you post a picture of what you have.
Alan
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1980 Fire truck Sold
PostPosted: Sat Mar 03, 2012 11:58 am    Post subject: Reply with quote
Yes, 924 have a collapsible section from the factory. It looks like a perforated cylindrical tube with holes in it partway down the steering column.
staticsan
PostPosted: Sat Mar 03, 2012 3:35 pm    Post subject: Reply with quote
There isn't a perforated section in the column visible underneath the dash. Sorry, I should have mentioned this before. I'll pull the wheel off and have a look right up high, then.
This topic came up some months back
http://www.924board.org/viewtopic.php?t=35644&highlight=im240
Wade.
staticsan
PostPosted: Sun Mar 04, 2012 4:03 pm    Post subject: Pics... Reply with quote
Right. Okay.
This is what under the dash looks like:
Pulling the steering wheel off and removing the switches and ignition lock I find this:
It might be a little hard to see but there is no honeycomb section in this piece of column.
But in the process of removing the steering wheel, take off the pad and I see the following:
... which is a honeycomb section! It's about 5 inches long, though, which may not be long enough.
I will talk to the engineer tomorrow. It's dead easy to show him the steering wheel, whether it's in the car or not. Much simpler than replacing the column.
Wade.
Muz924
PostPosted: Sun Mar 04, 2012 4:55 pm    Post subject: Reply with quote
Wade,
if the steering wheel is the one you bought off me its collapsible
as its off my 1978 aussie spec car.
The steering shaft you have is the later type as i posted in the previous post. The later type is better as the collasping is controlled within itself.
(one pipe sliding inside the other).
Your UK spec car will have UK compliance plate on it, one of the numbers will be for "collapsible steering column".
Research which number relates "collapsible steering column" and show your road worthy guy. (I cant believe he thinks an 1982 german car dosn't have one!!!!)
Post a pic of the UK compliance plate and i'll try looking it up for you.
1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car)
staticsan
PostPosted: Sun Mar 04, 2012 7:44 pm    Post subject: Reply with quote
Muz924 wrote:
Wade,
It is indeed that wheel. Thank you so much for posting - it saved me having to ask!
First I have to find the UK compliance plate. I haven't seen anything so far that looks like a UK compliance plate.
Unfortunately, I can believe he thinks a 1982 German car doesn't have one: he can't see evidence of it and his livelihood rather relies on his assessments being verifiable by the authorities. Whilst I can take the steering wheel in to show him, taking that piece of steering column is going to be a little more difficult. But if I have to, I have to.
Wade.
Muz924
PostPosted: Sun Mar 04, 2012 9:02 pm    Post subject: Reply with quote
Maybe the the UK cars don't have a compliance plate as they already comply with German standards!
What about getting a porsche garage to confirm in writing it is indeed a collapsible type?
You say he can't see evidence of it.....what does he think the small shaft going into the larger shaft is for!!!!
Or go to an engineer that knows what he is looking at, pretty soon he will be asking for evidence of curtain airbags and ESP
staticsan
PostPosted: Sun Mar 04, 2012 9:15 pm    Post subject: Reply with quote
The larger "shaft" visible is actually part of the steering lock. Haynes calls it a "steering column casing".
I did some more research. There is a type of collapsing column that doesn't use a honeycomb structure because it uses a friction fitting between two cylinders, pretty much as you describe. If mine is of that type, then this portion is inside the casing.
Wade.
scm924s
PostPosted: Tue Mar 06, 2012 2:37 am    Post subject: Reply with quote
The steering column is NOT collapsible, the steering wheel boss on the standard wheel is the collapsible element.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
PostPosted: Tue Mar 06, 2012 3:24 am    Post subject: Reply with quote
Another part of the collapsable design is the steering shaft comes in a couple of pieces that are offset and connected by u-joints. If the steering rack moves towards the passenger compartment for some reason, like a frontal impact, the u-joints allow the steering shaft(s) and rack to side-step and move towards the passenger compartment without moving the steering wheel towards the driver.
Yes, that perforated thing you have in the pics is what I was talking about.
I think your "engineer" is a dolt. This design has been employed almost universally since the 1960s.
staticsan
PostPosted: Tue Mar 06, 2012 2:35 pm    Post subject: Bad news, guys. Reply with quote
The engineer got back to me and has been doing his own research, including locating another engineer who has done certification work for Porsche and has also been involved with sorting out problems with steering columns.
He won't pass it without a honeycomb section in the column itself. If anyone has one I can buy, then I'm interested. The honeycomb section in the steering wheel boss is good, but not enough.
Tomorrow's task is to pull the column actually out on the off-chance there is a collapsing section hiding in the steering lock tube. If there is, then he will pass it.
Wade.
Muz924
PostPosted: Tue Mar 06, 2012 7:49 pm    Post subject: Reply with quote
I cant believe your Engineer will only approve the pre 1980 version of the steering column!!
Try contacting a fellow member Ron "unheardofinstruments" he might have older style (honeycomb) steering column available as well.
I have a spare from my 1980 however its the same as the "non compliant" version you currenty have.
They are held on by 4-bolts (and the uni joint in engine bay), the fun part is getting all the indicator/wiper stuff off, based on your photos you have already done that.
Good luck mate!
john h
PostPosted: Tue Mar 06, 2012 8:32 pm    Post subject: Reply with quote
pretty sure I have a couple of old ones here in NZ so I could send one to you. Not sure how much it would cost you for postage. I won't be down to the garage till the weekend and will look then.
