williamtomisser
Posted: Tue Jan 17, 2012 1:41 pm Post subject: need help |
i have a 77 924 that is cranking but not firing it fired yesterday and now it is having problems. i redid some wiring and cleaned some grounds and i looked up and i saw something smoking after i reconnected the ground. there a seperate small cylinder with two almost d battery sized things on both sides. it connects to the distrubutor. i think that it says transistor on the side. anyways one of the d battery sized things was getting so hot it began burning a rubber cord it was touching. what are these parts? also what would be an easy way to test the distributor for correct firing. and if you have had similar problems what did you do to correct them.
thanks |
Posted: Tue Jan 17, 2012 2:09 pm Post subject: |
sounds like the coil and two resistors. _________________ Porsche 924 1984 (UK import) NA
williamtomisser
Posted: Wed Jan 18, 2012 2:08 am Post subject: |
| first thanks for helping me i bought this 924 3 days ago and its already having problems and i have no money to take it to a pro. anyways is this the ignition coil? also how would i test it thanks |
tyfighter123
Posted: Wed Jan 18, 2012 4:57 am Post subject: |
The two resistors or ballasts smoke because they get hot from cranking it over so much. Do you have fuel and spark? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 924S 1987 (parts car)(cut up and recycled)
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
williamtomisser
Posted: Wed Jan 18, 2012 6:31 am Post subject: reply |
| i dont think i have spark i unhooked the ignition coil and connected some wire to the ground and dragged the ground on the engine block with the main coil wire close to the block to see if it would spark but it didnt i have to order this part out of state and i need this vehicle to go from county to county to attend university so i kind of need this to be the correct shot thanks |
williamtomisser
Posted: Wed Jan 18, 2012 6:34 am Post subject: reply |
| i dont know if i have fuel, i cant hear the fuel pump relay clicking the relay clicked on my old toyota but i dont know if these ones do or not whats a good way to test for fuel |
Posted: Wed Jan 18, 2012 6:50 am Post subject: |
Wait, you're broke and bought a non-running 924 as a commuter car?
williamtomisser
Posted: Wed Jan 18, 2012 7:02 am Post subject: reply |
| no the car ran fine for the first 2 days and had 84k original miles on it it still runs it just wont fire alot of the parts are original and i think this is one of them it just wore out im not broke i just dont have any tools here im from alaska originally and came to california to go to school |
musicalannette
Posted: Sun Mar 11, 2012 12:48 am Post subject: |
There are three things you need, spark, compression and fuel.
I doubt the compression will go wrong overnight, it is usually something that gets progressivley worse unless you have done something like run the engine until it gets really really hot (usuall on physically large gaskets such as a straight six), or run it with the oil light on.
So you can probably safely say it's fuel or spark.
A lazy way to check the fuel is there is to crank the engine for 20 seconds with full throttle applied, then get someone to put their nose at the exhaust and crank it while sniffing (again applying full throttle), if you smell petrol out the exhaust then theres fuel there.
To check the spark, take out a spark plug (or get another spark plug) and and connect one spark lead to the spark plug that you have either taken out or found from somewhere, place this on the engine block and look for a spark jumping across the end of the electrode while you crank the engine over, it should be nice and bright, blueish in colour, when it's yellow it is normally a sign of a weak spark.
WHATEVER YOU DO, DO NOT MESS AROUND WITH MOVING THE DISTRIBUTOR.
You will adjust the timing and have to start from scratch, this should not have changed.
One of the three is missing, hope this helps.
Personally, with beetle parts being so cheap and the zinc oxide electroplating on the shell, this is the cheapest classic car you will ever own.
Clever choice. Good luck. _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
williamtomisser
Posted: Sun Mar 11, 2012 1:00 am Post subject: bad news |
yeah I replaced the secondary engine pump and 1 week ago someone backed into me and now its totaled LOL I got it for 1500 but the original price last year. was 4700 do u know how much I should ask the insurance company for the losses its in prestigious condition I will put up pics real quick lemme know what. u think [img][/img] |
musicalannette
Posted: Sun Mar 11, 2012 1:11 am Post subject: |
I don't know, best ask some guys out in the states. There not worth alot here in the UK. _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
