Early Fuel Breather
Andrew NZ
PostPosted: Mon May 07, 2012 8:12 am    Post subject: Early Fuel Breather Reply with quote
Hi, does any one have a diagram of the 1977 fuel tank breather system? I can only find info on the later ones on here, which looks quite diferent to mine.
I just need to know what goes where so that I can check that it's working properly, as the tank seems to be under a lot of pressure and was blowing out the filler cap on the last rally.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
Andrew NZ
PostPosted: Mon May 07, 2012 11:14 am    Post subject: Reply with quote
I've managed to find some pictures of the early set-up on this post http://www.924board.org/viewtopic.php?t=36494&highlight=fuel+tank
and have also found this one that explains a bit about what is happening and how to fix it: http://www.924board.org/viewtopic.php?t=32958&start=0&postdays=0&postorder=asc&highlight=early+fuel+cap
Hopefully this will solve my problem.
Andrew
1977 RX924 race car
