headlight switch issue
philk
PostPosted: Fri Apr 20, 2012 12:08 am    Post subject: headlight switch issue Reply with quote
Driving last night the lights went out on my project car..touching the switch the came back on, but there seems to be a short cutting them out..made it home tried to flip the light switch, but it is frozen...won't move...turned car off, but lights stayed on
Tried to re-start twice and nothing happened..third time it started, but still could not move the switch..
removed the battery (-) cable so it wouldn't run down
any ideas?
edredas
PostPosted: Fri Apr 20, 2012 4:01 am    Post subject: Reply with quote
I once had the motor relay short out and melt my switch, causing what you describe.
The switch will need to be replaced, but you must find what caused the issue, or it will only melt your new switch.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
philk
PostPosted: Tue Apr 24, 2012 4:39 am    Post subject: Reply with quote
thanks I figured it's something like that..I'll ck relay first..
philk
PostPosted: Wed Apr 25, 2012 12:21 pm    Post subject: Reply with quote
I ck'd the relay and it works as it should...switch is burnt/melted on inside.
did you finally find what caused your switch to short/melt?
the car now does not crank unless jumped...and it starts...I thought it may not have been charged well when I bought it and really haven't had a chance to really drive it to charge...
but it should at least turn over after driving about 10min....
edredas
PostPosted: Thu Apr 26, 2012 7:45 am    Post subject: Reply with quote
The relay was the problem in my case. It must have been damaged while I was working under the hood.
If your relay is fine, then I would check for bare wires. Also make sure you are using the correct fuses. This will help protect the switch.
