sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Thu Apr 26, 2012 9:36 am Post subject: ARGH! Leaking battery tray!!!! |
Well, it has been raining something fierce in these ol mountains, and my passenger floor is soaked.
I traced the culprit to the battery location....someone years ago already fiber glassed it(ive heard that this is a common thing)
Wondering what you guys think I should do? Should I tear out and replace the fiberglass....
or!
Should I get some of that liquid rubber/rhino liner, and coat the whole deck with it?
replacing with new metal is not an option. I no longer have a TIG. _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
mikebola
Joined: 07 Sep 2009 Posts: 361 Location: Parkside, PA
Posted: Thu Apr 26, 2012 9:42 am Post subject: |
mine had two holes in it the size of dollar bills when I got it. I cut out all the rust, painted it with rust converter and regular rattlecan black, then riveted in a plate of aluminum. about 6 ounces of spray rubber filled the cracks and made it so it'll last a good long while.
if the fiberglass seems well done and isn't delaminating from itself or the metal, I'd say coat it. but ymmv. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
sciroccosteve
Posted: Thu Apr 26, 2012 9:56 am Post subject: |
| mikebola wrote: |
if the fiberglass seems well done and isn't delaminating from itself or the metal, I'd say coat it. but ymmv. |
The fiberglass seems to be fine. no flaking, seperation etc...just somewhere it is letting all the water in.
Bummer about your holes man, I had a VR6 jetta I bought for next to nothing because of holes like that on a front suspension support. Cut out all the rust, welded in new metal...worked great. _________________ 1979 924
2000 V6 Passat
staticsan
Posted: Thu Apr 26, 2012 12:13 pm Post subject: |
Check there is, in fact, a drain hole through the firewall, too. Mine had been repurposed for the battery ground cable. I didn't think that was such a great idea and put in another hole for that.
Wade _________________ '82 British NA - Which I think I've been very lucky with! |
sciroccosteve
Posted: Thu Apr 26, 2012 12:32 pm Post subject: |
| staticsan wrote: | Check there is, in fact, a drain hole through the firewall, too. Mine had been repurposed for the battery ground cable. I didn't think that was such a great idea and put in another hole for that.
Wade |
I know that drain hole! When I brought her home, I had noticed damp carpet. So i cleaned out the drain hole. Problem seemed to go away.....
Nasty and constant down pours recently though, its happening again. _________________ 1979 924
2000 V6 Passat
MikeJinCO
Posted: Sat Apr 28, 2012 7:28 am Post subject: |
I do fiberglass work often, just make sure to use an epoxy resin rather than polyester as it tends to delaminate on repair jobs. Polyester is the norm for molding, but is not a good adhesive. The local boat building folks should all have both epoxy and fiberglass. Mine had some rust so I gave it a couple of coats of POR15 that I had on hand and then 4 or 5 coat so Duplicolor Truck bed coating. I just have to figure out a front battery anchor mount as the stud is broken. _________________ Mike
'67 MG Midget Dp
mikebola
Posted: Sat Apr 28, 2012 10:21 am Post subject: |
| MikeJinCO wrote: | | I just have to figure out a front battery anchor mount as the stud is broken. |
I used a nut and carriage bolt that I put through the aluminum on mine (the original steel on yours) It seems to work pretty well. _________________ proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs... |
joecitizennn
Posted: Sat Apr 28, 2012 12:53 pm Post subject: |
| sciroccosteve wrote: |
you might check your windshield seal and door gasket too _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
Slam
Posted: Wed May 02, 2012 12:54 pm Post subject: |
I second the windshield seal. The adhesive dries out and leaks. The best way to test you battery box is to wait until all is nice and dry and then have an assistant (heh...) pour water into the battery box while you stick your head under the dash. Many leaks can't be seen with the naked eye. (I finally had a chance to use the word 'naked' on a car site...)
I'm a fan of fibreglassing these and have done all our cars. _________________ '88 944 Auto - may or may not resurrect |
brealytrent
Joined: 28 Dec 2008 Posts: 414 Location: Goldsboro, NC
Posted: Mon May 07, 2012 1:40 am Post subject: |
I have a similar problem:
The battery box was pretty ratty, so I cut out all the bad metal, riveted in a new aluminum piece, then put a few layers of fiberglass on that and painted it. Still leaks? I can't see where either as the AC system is in the way Oh, and then there is the myriad of other leaks, especially coming from the sunroof that doesn't seem to get better no matter how clear the drain lines are.  _________________ 1977 Porsche 924 - sold
1980 Porsche 931 - sold
1984 Porsche 928 'S2' Euro - sold
2016 Ford Fiesta ST - sold
2009 Porsche Cayman |
Slam
Posted: Mon May 07, 2012 2:41 am Post subject: |
Hmmm.. Maybe have a look and see if the drain tubes have come adrift from the nipples on the drains themselves (heh... I got to say nipples too...).
One other thing is to swap out your quarter window seals. _________________ '88 944 Auto - may or may not resurrect |
brealytrent
Posted: Mon May 07, 2012 7:32 am Post subject: |
how do you tell if the hose has come off without cutting sheet metal? I know at least three of the lines are good because I can blow air through them to the drain hole in the gutter system. The one I'm not so sure about is over the driver through the a-pillar, but i never have water drip from there. _________________ 1977 Porsche 924 - sold
