Water Pump Squeak
PostPosted: Wed May 09, 2012 3:08 am    Post subject: Water Pump Squeak Reply with quote
Took of the belt and turned the pump by hand. In both directions, there is a soft squeak, like rubber rubbing on something. No discernible play.
Should I replace?
PostPosted: Wed May 09, 2012 5:01 am    Post subject: Reply with quote
In my opinion, which is worth what it costs you to read this, if it ain't leaking, then no. That's probably just the seal making noise.
What's your coolant like? Maybe it needs refreshing, as on of its properties is supposed to lubricate this seal.
78 924 NA
5-lug
