More charging power? (stereo install soon)
sciroccosteve
PostPosted: Wed May 09, 2012 6:30 am    Post subject: More charging power? (stereo install soon) Reply with quote
Hey fellas, hows tricks?
Anyways,
I am going to putting a stereo into my car this weekend...(I do car stereo design in my free time for peoples) and something struck me as a possible issue.
A 75amp alternator.
Is there a replacement alternator, I would like to have at the very least 90amp, would prefer 120.
I run amps to everything I do. This car will have 4 5" woofers, 2 in doors(or molded into the wall on the door side) and 2 behind the doors, thats one amp. It will then have 4 tweeters, 2 in dash, 2 above rear seat...another amp. it will then have subs put into the rear, which is another amp.
So, in short: 3 amps, 4 tweeters, 4 woofers, 2 subs. I just dont think 75amp will cut it.
Any ideas? cross reference parts? Something I can do to make my alternator deal well with this much power coming in?
I am hip to ideas, and would love to hear about other stereo setups in the 24's.
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns
BionicBalls
PostPosted: Wed May 09, 2012 9:55 am    Post subject: Reply with quote
There is a 90A alternator available. Other than that, it is going to take a bit of fabricating, but you can install a CS-144 alternator in you car. It has a ton of different amps available all the way up to 350A!
Check out my how-to write up:
http://www.924board.org/viewtopic.php?t=36143
1980 924 NA
1982 931
leadfoot
PostPosted: Thu May 10, 2012 6:10 pm    Post subject: Reply with quote
assuming your hooking in a farad capacitor for the power soak??
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
sciroccosteve
PostPosted: Fri May 11, 2012 12:34 am    Post subject: Reply with quote
Stu
Yes I am.
2000 V6 Passat
C. Montgomery Burns
PostPosted: Sat May 12, 2012 11:58 am    Post subject: Reply with quote
I have a 150A solution that is nearly bolt-in for both NA and 931, but it is not cheap. $245 + $20 drop shipped from the wholesaler. I've been running one in the 941 for a little over a year now with no issues. I also have one in the Club Sport. The only thing that is not 100% bolt-in is that the mounting bosses are made for 10mm bolts rather than the stock 8mm bolts on our cars. You can remedy this by getting a small section (<1 foot is sufficient, but I had to buy a minimum length of 3') of 3/8" ID copper tubing from your local hardware and cutting it to the length of the mounting bosses to use as a home-made bushing.
From this thread:
Here are some details from the spec sheet on my 150A replacement alt:
Max alternator output: 190A
Max output power: 2437W
Voltage set point: 14.5
Leakage current: 0.42
Ripple current: 42
Alternator turn on speed: 1531 RPM
Regulator activation speed: 1419 RPM
Output current table (tested at 12.8V):
1600 RPM: 72A
1800 RPM: 96A
2000 RPM: 116A
2400 RPM: 143A
3500 RPM: 169A
5000 RPM: 183A
6000 RPM: 190A
Terminals / Application: Universal J plug with 5 wires. Field is protected by "in-line" fuse. The alternator has an internal voltage regulator, as well as an internal fan and an integral shield on the back.
Click for high resolution images.
Last two images are as-installed on the new 941 motor with all stock mounting hardware and stock 931 belt.
