ac question
JEREMY74
PostPosted: Fri Aug 02, 2013 8:47 am    Post subject: ac question Reply with quote
when i run my ac it feels like the power lags down a little when the ac clutch goes on and comes back up when the clutch turns off. does this mean my compressor is going bad? thanks for the help.
1987 PORSCHE 924S
PostPosted: Fri Aug 02, 2013 9:35 am    Post subject: Reply with quote
It means you have a 25 year old German ac compressor that was inefficient at best when it was brand new. If cold air comes out, consider that a miracle.
JEREMY74
PostPosted: Fri Aug 02, 2013 9:58 am    Post subject: Reply with quote
yes nice and cold. just didnt have the lag to it before.
1987 PORSCHE 924S
JEREMY74
PostPosted: Sat Sep 07, 2013 11:42 am    Post subject: Reply with quote
i was wondering if my compressor is seizing up or lagging the belt will that hurt the engine?
1987 PORSCHE 924S
JEREMY74
PostPosted: Sat Sep 07, 2013 11:43 am    Post subject: Reply with quote
1987 PORSCHE 924S
edredas
PostPosted: Sat Sep 07, 2013 6:32 pm    Post subject: Reply with quote
The compressor puts quite a load on the engine. The DME knows when the A/C is turned on and uses the Idle Stabilizer Valve (ISV) to compensate for this load by increasing the idle speed. However, this can't happen if the Idle switch on the throttle body is out of adjustment or the ISV is no longer working... so be sure to check them.
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
JEREMY74
PostPosted: Sun Sep 15, 2013 10:08 am    Post subject: Reply with quote
can you tell me how to check that its working ok? i am pretty handy if i have some place to start at.
1987 PORSCHE 924S
JEREMY74
1987 PORSCHE 924S
edredas
PostPosted: Mon Sep 16, 2013 5:13 pm    Post subject: Reply with quote
Here's a link showing how to test the throttle position switch. Before you start troubleshooting, verify that the switch is adjusted properly by rocking the throttle cam back and forth with your ear next to it. If you hear a faint click, it is correct, but could still be faulty.
http://www.clarks-garage.com/pdf-manual/ign-03.pdf
If the throttle switch is working properly, then it could be the ISV. I'm not aware of any way to troubleshoot it short of removing it and verifying its operation. However, I do like to touch it and see if it is vibrating when the key is in the ACC position before going that far. That will atleast give you an indication if there's a wiring problem.
JEREMY74
PostPosted: Tue Sep 24, 2013 8:46 am    Post subject: Reply with quote
thanks for the help ill try to work on as soon as i can find some time. thank you for the link.much appreciated.
1987 PORSCHE 924S
JEREMY74
1987 PORSCHE 924S
