is there a main fuse in my 924?
snakoil
PostPosted: Fri May 25, 2012 5:45 am    Post subject: is there a main fuse in my 924? Reply with quote
I have a 1979 924 NA
I was removing some PO custom wiring on ym car to bring it back to OEM
after a quick testing the car made like it was trying to start and then everything shutted down, no power anyware.
I tested the battery and validated all fuses in the relay box
I verified my wiring and I believe I should be correct.
Is there another fuse in the engine bay that might have blown or could it be one of the relay that blew?
right now turning the key does nothing at all on the car.
thanks
1979 924 NA
staticsan
PostPosted: Fri May 25, 2012 9:55 am    Post subject: Reply with quote
That sounds like your ignition switch has failed, actually. I could be wrong.
Wade.
'82 British NA - Which I think I've been very lucky with!
Luvmy80-924
PostPosted: Fri May 25, 2012 10:16 am    Post subject: Reply with quote
Probably a great place to start, check voltage in and out anyway.
1980 924 N/A Everyday Driver
1986 930
And now a 1980 931
corroded battery terminal?
snakoil
PostPosted: Fri May 25, 2012 11:08 am    Post subject: Reply with quote
Battery terminals are good-ish
I tought of the ignition swith also tonight... I just don't have a clue how to troubleshoot this.
I guess i'll have to get a multimeter as my only wiring tool so far consist of a test light.
If i try to bypass the switch like they did in go e in 60 seconds would it work?
1979 924 NA
CorsePerVita
PostPosted: Fri May 25, 2012 11:51 am    Post subject: Reply with quote
No power anywhere:
- Check your main ground to the firewall. If it is severely corroded it making a horrible connection you may very well get nothing. I've seen one so corroded that it looked just like dirt. At first I thought nothing of it, after I touched it with sandpaper I realized it was corroded. Ended up replacing it.
- Ignition switch can fail in different ways. You have a I/II/III on the ignition switch. I is off, II is on, III is start. Do you get /anything/ on II or III? A click? Anything? If not I would check grounds.
Here's a good place to start. Get a multimeter (test light will probably work). To see if your main ground is worth a darn touch the positive tester to your 12v on the battery. Then touch the ground tester to a chassis ground nearby. If you register nothing, your main ground is bad. If you see 12v pop up then it's fine.
The battery to firewall ground has a tendency to rust under it if there is any rust issues on the car, and with time, could eventually have enough resistance that it simply stops making a connection all together.
Since there is not a "main fuse", it's safe to say if /nothing/ is working there is a huge break somewhere in the harness, or the terminal, or a ground. It is very possible that you could have something like the headlights working, but have no dash lights. Or perhaps you could have the wipers working, but have no headlights, etc etc... there are many separate circuits.
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
snakoil
PostPosted: Fri May 25, 2012 8:17 pm    Post subject: Reply with quote
I'll check the ground tonight
Like I said I got nothing at all, no electronic clickin sound when I turn the key and no wiper, dash, headlights. the car responds the same way as when I have the battery disconnected.
I'll keep you guys informed of what I find tonight
1979 924 NA
CorsePerVita
PostPosted: Fri May 25, 2012 8:19 pm    Post subject: Reply with quote
best of luck to ya!
- 1999 Ducati 900SS
staticsan
PostPosted: Fri May 25, 2012 8:41 pm    Post subject: Reply with quote
I'm guess a little bit, but I noticed on my car that there is a threaded hole near the battery probably intended for the ground cable. However, a previous owner had put a longer cable on and terminated it instead where the engine is also grounded to the body - on the mount for the coil.
It's probably the only really good thing a PO has done on my car, but it does suggest that the original, factory-fitted ground point was really not such a great choice.
Wade.
snakoil
PostPosted: Sun May 27, 2012 10:52 am    Post subject: Reply with quote
Thank you guys!
I got my testlight out and started looking at ignition wires
And never got anything, wondering if my testlight was
Working i tried directly on the battery connectors.
Seems my positive battery connector was more than just dirty on the outside.
After a quick sandpaper work i now got power again!
I do have a fuse that blows when turning the key but that will be for another day.
Thank you for your guidance guys, it helped a lot as i would have never doubted a battery connector.
1979 924 NA
