Steering wheel question.
staticsan
PostPosted: Sat May 12, 2012 6:51 pm    Post subject: Steering wheel question. Reply with quote
I have a persistent problem with my steering wheel, specifically the contact for the slip ring for the horn button. It likes to ground itself against the surrounding switch mounts, which (obviously) sounds the horn! I did add some insulation tape under it, hoping that that would fix the problem, but it's either shifted or hasn't worked.
One thing that I did notice is that the wheel and the column have some play. Pulling the wheel towards me can solve the problem. That makes me wonder if there isn't a spacer I'm somehow missing. The Haynes book shows it, but I don't have such a thing.
For the meantime, I've pulled the horn fuse. Which is slightly inconvenient, as it means I have no horn. But that's be
Wade.
'82 British NA - Which I think I've been very lucky with!
leadfoot
PostPosted: Sat May 12, 2012 6:58 pm    Post subject: Reply with quote
the answer is yes, there's meant to be a spacer,
i've seen two types; a more rubbery plastic one, and a hard plastic one with some grooves in it.
normally they come with the bearing when you buy it....
I was also missing it on this car, but having an abundant supply of welding gas bottle blanking plugs (plastic) I noticed they were almost identical give a slightly larger diameter, cut the bottom out and a slit in the side and viola, instant spacer.
now don't ask me if it will either last or is a means of insulating the horn contact but it's working for now...
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
staticsan
PostPosted: Sat May 12, 2012 8:45 pm    Post subject: Reply with quote
Okay, I guess I can fabricate something. Do you know how thick it is supposed to be.
Wade.
Harm
PostPosted: Sat May 12, 2012 9:25 pm    Post subject: Re: Steering wheel question. Reply with quote
VW # 171 419 549
Length 32,4mm
Inner ∅ 22mm
Outer ∅ 28mm
The toothed side is slightly thinner, ∅ 24mm about one centimeter inward.
HTH
leadfoot
PostPosted: Sat May 12, 2012 10:08 pm    Post subject: Reply with quote
ok there's that one and the one above the bearing that I was refering to..
Stu
staticsan
PostPosted: Sat May 12, 2012 10:57 pm    Post subject: Reply with quote
I'm confused. Harm, where does that go? Between the lock bearing and the steering wheel?
Wade.
Harm
PostPosted: Sat May 12, 2012 11:16 pm    Post subject: Reply with quote
Yes, that is the spacer between the lock bearing and the steeringwheel.
staticsan
PostPosted: Sun May 13, 2012 9:52 pm    Post subject: Reply with quote
Cool. I'm sure I can make something like that!
Wade.
Harm
PostPosted: Sun May 13, 2012 10:36 pm    Post subject: Re: Steering wheel question. Reply with quote
staticsan
PostPosted: Mon May 14, 2012 10:12 am    Post subject: Reply with quote
Harm you are amazing! If I had a 3D printer, I could make one!
Wade.
Muz924
PostPosted: Wed May 16, 2012 1:46 pm    Post subject: Reply with quote
Wade,
I have got a spare one of those you can have , only cost you the postage!
Santo
1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car)
PostPosted: Sun May 20, 2012 3:29 am    Post subject: Reply with quote
I do have the same problem with my new toy. After taking the steering wheel of and the stalks, that spacer came of in the same time and i did d recon in which sequence.
i think i am able to fix that one now.
thanks Nobbi
staticsan
PostPosted: Sat May 26, 2012 5:52 pm    Post subject: Reply with quote
Spacer in and the immediate benefit is that the vertical play in the steering is gone! Wonderful! Next step is to put the horn fuse back in, though I'm going to wait a few days and make sure I don't hear the relay clicking at inopportune moments.
Wade.
