snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Wed Apr 04, 2012 11:30 pm Post subject: Replacing steering column switched |
I want to replace my entire steering column switch with steering lock as mine is worned out and cracked in several places.
When I look at DC website I see 2 parts number with same description, which one would be the right one as the prices are quite different
http://dcauto.gotdns.com/illustration/index/948968862
1 113953503BG: 200$
(1) 477953503B (79-): 120$
why is the second one in parenthesis?
if one of you could bring light to this or if you have that part available in your own parts bin for cheaper please let me know! _________________ 1979 924 NA |
Posted: Thu Apr 05, 2012 6:22 am Post subject: |
one is early and other late model '79 onwards.
skinny paddles are the early type. _________________ Porsche 924 1984 (UK import) NA
snakoil
Posted: Thu Apr 05, 2012 6:26 am Post subject: |
So early model is the cheaper one, am i correct?
Will the later model also fit on my steering column? _________________ 1979 924 NA |
Posted: Thu Apr 05, 2012 6:28 am Post subject: |
usually 477 numbers are later type because they were used on 944 and 924S
not interchangeable _________________ Porsche 924 1984 (UK import) NA
snakoil
Posted: Fri Jun 01, 2012 12:07 am Post subject: |
after seeing the quality of parts i recently got from dc automotive, I am not getting anything that will be visible from them anymore.
Anyone here as 1 in really good condition for sell? _________________ 1979 924 NA |
Posted: Fri Jun 01, 2012 3:30 am Post subject: |
I have one out of my '80 turbo car, flat paddles. The little white plastic sliders for the turn signal, one is broken, if you might have one from yours. 75 bucks delivered. dave. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Fri Jun 01, 2012 5:12 am Post subject: |
I'm pretty sure the metal paddle and plastic paddle versions are not interchangeable. I don't remember which is which, but one attaches by 3 screws and one with 4; I believe the plug harness are different too. So you need to make sure you get the correct unit.
Be wary of DC Automotive...lots of complaints about them. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Jun 02, 2012 3:47 am Post subject: |
I have both, not interchangeable. _________________ '83 944 Track car.
