snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Wed Aug 29, 2012 10:25 am Post subject: What are these hidden under ball of duck tape? |
In an effort to bypass my heater core I removed my ignition coil and found 3 balls of ducktape behind my engine.
removing the duck tape uncovered the following 3 plugs
any of you can help me out figure what their purpose is?
Those look like vaccum port but on a water pipe so i'm a bit confused.
If they should be connected to something please let me know what
If you got a picture even better!
also I noticed the heater core water tubing(short one) is a size a bit bigger than 3/4 and ends up in 5/8, any idea if I can expand a 3/4 to fit on the hole or cut my OEM hose and get a 5/8 coupler to plug another hose end? _________________ 1979 924 NA |
musicalannette
Posted: Wed Aug 29, 2012 4:27 pm Post subject: |
I am not sure, never looked there. but looking at the photo, the right hand one looks like an electrical temperature sender, the middle one looks like a mini diaphram pressure switch the left im not sure (on second examination, could they be a blocked off trickle water feed?).
But if there in the water line and not standard, perhaps someone had trouble with the water system, or more likely,as you are up in the cold of canada could it be a monitor system for a engine pre-heater or even a warm feed from a removed remote cockpit pre-heater? trouble is, if its removed, you wont know exactly what each does or if there was a flow cut valve in circuit as they will probably have been valuable and removed for the next car or flogged on ebay which could lead you head scratching.
Sorry not much help. Best ask someone or have a look in the book to see if it isnt something to do air-con or smog emmisions. dont have a book with me and i dont have either fitted to my car.
I think idiola might be able to help as he has taken his car back to nut and bolts and built them back up again.
hope this help _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
Posted: Wed Aug 29, 2012 5:22 pm Post subject: |
This is part of the EGR system. You'll find more details in the Hayne's manual. _________________ 78 924 NA
5-lug |
Posted: Wed Aug 29, 2012 5:27 pm Post subject: |
| !tom wrote: | | This is part of the EGR system. You'll find more details in the Hayne's manual. |
And again! _________________ '80 924 Turbo |
snakoil
Posted: Wed Aug 29, 2012 7:29 pm Post subject: |
I elieve EGR system was only on california cars for 924
My car was imported from California in the late 80's
Since they are pluggued offf i assume PO tried to remove EGR system.
Maybe i could do a proper removal then
If ant of you has a picture of this hose on their car it would be helpful.
Knowing that this part is a simple hose in other 924 i will simply replace it and call it a day  _________________ 1979 924 NA |
DOCO
Joined: 04 Aug 2006 Posts: 1111 Location: Keswick Ontario Canada
Posted: Wed Aug 29, 2012 10:17 pm Post subject: |
my car is from cali also and they are sensors for the egr system.mine are all gone now as i have installed webbs on mine.i may be able to come up with a pic of where the hoses go if you want them hooked up again DocO _________________ Doco "where am i going and why am i in this handbasket"author unknown
79 924 N/A "Webster"
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
snakoil
Posted: Wed Aug 29, 2012 11:56 pm Post subject: |
well seeing the car is currently running with them unpluggued and the fact I want to go carburated myself I might be more interested in what this pipe looks like in your current status.
did you simply replaced it with a regular hose or made a big ball of duck tape to cover them?  _________________ 1979 924 NA |
Posted: Thu Aug 30, 2012 2:57 am Post subject: |
The one with the electrical connections is referred to in PET as "thermo valve", and the other two are referred to as "temperature switches", although that does little to reveal their intended purposes. The ones with the vac ports, you don't even need to plug up the holes, just leave the switches in place and the vac ports disconnected as is, should have little impact on how the car runs, although IIRC it has something to do with US emissions control, so might affect your emissions output to some extent, and might be an issue if you have to undergo visual inspection or smog testing. _________________ erstwhile owner of just about every 924 variant ever made |
DOCO
Posted: Thu Aug 30, 2012 3:08 am Post subject: |
LOL no i removed the tube out of the system and directly hooked up the hose.might have used a flush tee ill have to look _________________ Doco "where am i going and why am i in this handbasket"author unknown
_______
/______\
[+]___[+]
\0 924 0/
[__]..[__]
"WEBB STR" |
