Hot Spark Electronic Ignition
chrisvs
PostPosted: Sat Jul 21, 2012 4:38 am    Post subject: Hot Spark Electronic Ignition Reply with quote
My apologies gents if the answer is here and I haven't found it....
Has anybody used these "Hot Spark" EI units to replace the points and condenser? I am starting to look at tune up parts, and was wondering if it was worth it to do this conversion?
Any thoughts are welcome.
http://www.hot-spark.com/1-porsche.htm
1978 924 4-spd
PostPosted: Sat Jul 21, 2012 8:20 am    Post subject: Reply with quote
It looks similar to a Pertronix solution. Can't see why it might not work, its similar in function to the later style ignition system used on the 79 and later cars.
Anything solid state will almost certainly be better than points and condenser.
The curve will still be managed by the internals of the distributor, which is a good starting point.
So if you're ultimately looking to improve the ignition curve, you'd need to have someone alter the curve with different weights, springs, etc. That or lock it down and manage the timing using a digital ignition control solution, which might be ideal, but requires a certain amount of knowledge and work to accomplish.
daniel
PostPosted: Sat Jul 21, 2012 1:59 pm    Post subject: Reply with quote
I got one of these of ebay, didnt work at all. I now use the pertronix one, works great
1989 944 Cabriolet
chrisvs
PostPosted: Tue Jul 24, 2012 12:50 am    Post subject: Reply with quote
Thanks for the feedback gents. I am not looking at improving the curve, just replacing the points and condenser once it is time to service them. I will look into the pertronix one if that is the reliable solution.
1978 924 4-spd
PostPosted: Tue Jul 24, 2012 12:19 pm    Post subject: Reply with quote
What points and condensor? A '78 doesn't have points.
78 924 NA
5-lug
Horizonblue
PostPosted: Tue Jul 24, 2012 5:17 pm    Post subject: Reply with quote
I installed HotSpark in my car, approx 1.5 year before pulling the engine and starting the EFI conversion. I also replaced the coil, spark plug wires, and spark plugs. I can recommend such a tune up. The engine could idle low and steady, and was easy to start. No problems at all.
Euro 924, 1976
/P.G. Andersen
