Intake plenum idea.
Shurick
PostPosted: Sun Mar 22, 2009 8:02 pm    Post subject: Intake plenum idea. Reply with quote
Full size: http://pics.livejournal.com/woxed/pic/000ayzc2
It's just a trial fit to ensure that in could be done.=)
WBR, Shurick
'86 924S -- R.I.P.
https://www.instagram.com/ru_pacecar/
Raceboy
PostPosted: Sun Mar 22, 2009 9:57 pm    Post subject: Reply with quote
I think it looks good but perhaps using custom flange to head or 924 Weber manifold is necessary. Needs to be modified for 931.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Shurick
PostPosted: Mon Mar 23, 2009 1:04 am    Post subject: Reply with quote
The head side flange is not a problem. A lot of welding, but nothing impossible.
WBR, Shurick
'86 924S -- R.I.P.
Rich H
PostPosted: Mon Mar 23, 2009 4:50 am    Post subject: Reply with quote
What are the bits from?
gegge
PostPosted: Mon Mar 23, 2009 5:25 am    Post subject: Reply with quote
Intake from an 16V golf, 41mm and upsidedown? Please be advised that the flow is bad for the first runner, 133-150-156-156cfm@28´. I did some research and was close to buy the Dahlback racing inlet. The large port 51mm got the same problem 175-202-198-198cfm@28´
Wasn´t the spacing wrong? I measured 90mm c/c for the VW runners and Porsche got 95mm?
Carl Fredrik Torkildsen
PostPosted: Mon Mar 23, 2009 5:46 am    Post subject: Reply with quote
Planning on pulling the turbo to see what has fallen inside?
Shurick
PostPosted: Mon Mar 23, 2009 6:45 am    Post subject: Reply with quote
The turbo plans are simple: rebild and 2664 cold side from audi. It should be exact dimentions as CGT turbo in result.
Yes, the intake bits are from VW Golf II with KR engine. The first runner flow problem is well known, but the stock porsche plenum is even more restrictive.The overall air consumtion of the original M31 engine is not big enough to outgrow the abilities of 16v plenum I think. The spacing is not a big problem. We'll weld it out.=)
WBR, Shurick
'86 924S -- R.I.P.
Shurick
PostPosted: Sun Apr 05, 2009 4:32 am    Post subject: Reply with quote
All parts are welded up. Needs some polish work, but already very pretty I think.
WBR, Shurick
'86 924S -- R.I.P.
flosho
PostPosted: Sun Apr 05, 2009 12:22 pm    Post subject: Reply with quote
I like it!!!
[This Space For Rent]
PostPosted: Sun Apr 05, 2009 12:35 pm    Post subject: Reply with quote
Impressive!!!
PostPosted: Wed Jul 22, 2009 10:03 pm    Post subject: Reply with quote
[/quote]
I like the universal 924 'bolt tray', bet everyone uses those!! In fact, even after tooling on down the road, bolts/nuts still stay there. Priceless!
931 twinturbo
PostPosted: Wed Aug 29, 2012 6:48 am    Post subject: Reply with quote
Any updates????
911 Targa 1974 Turbolook/Outlaw
964 C2 1992mod
924 Carrera GTS Look(Project)
924Na stock 1982Mod
*911S Targa slantnose 1975mod
*924Na 1977Mod Carrera GT kit
*944NA Type 1 1984Mod
*924 Turbo Serie2 1980mod
*924 Turbo Serie2 1980Mod
*924NA 1982Mod
PostPosted: Wed Aug 29, 2012 7:56 am    Post subject: Reply with quote
Grenadiers wrote:
I like the universal 924 'bolt tray', bet everyone uses those!! In fact, even after tooling on down the road, bolts/nuts still stay there. Priceless![/quote]
Unless you're running adjustable camber plates, then they fall through the hole
!tom
PostPosted: Wed Aug 29, 2012 12:58 pm    Post subject: Reply with quote
I've even found that the oil filler cap stays put there!
78 924 NA
5-lug
PostPosted: Wed Aug 29, 2012 3:47 pm    Post subject: Reply with quote
The bolt tray is priceless and so true. A possibility to improve flow might be to mill a tapered spacer that changes the throttle body angle probably by only a few degrees to improve the approach angle.
I could probably make one of these out of plastic on my cnc router if I had dimensions. Once the overall dimensions are set, trying different angles is a very quick change. I would not get a good enough surface finish to the spacer so that std. gasket material could be used without making an entire second holding device for every angle as my unit is a 3 axis rather than 5 axis machine. When I cut with a .125" round router bit and use a .008" cross feed I get a surface scallop of maybe .001-.002"(I can't measure it). The bolt holes would have to slightly oversize to compensate for angle change, and the bolt heads would no longer be square to the TB. I have quite a bit of 1/4" acrylic around and can also get 1/2" cutting board scraps easily. That could be fun.
Mike
